Question about Dryers
Have an Admiral Designer Series Heavy Duty 20 lb dryer (LNC7543A87) that seems to be only working on low heat -- venting also seems to be halved, but this may be a product of low heat output. Help.
dididsaythat
  • 291 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
Krazytech
  • 725 Answers
SOURCE: I have an Admiral Designer
pull the pulley toward the motor the belt goes to the outside of the pulley... let me know
Posted on Jul 23, 2008
  • 21 Answers
SOURCE: dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Posted on Dec 26, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Dec 10, 2009 | Admiral AW22 Top Load Washer
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Dryers Logo
73 people viewed this question
Top Dryers Experts
