Question about Panasonic KX-TGA101S Cordless Handset
Panasonic kx-tga101s battery charge problem
Phone works, but battery charge shows only one bar even for fully charged batteries, regardless of whether they are charged in the handset or with a NiMH battery charger.
5 Suggested Answers
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
cnavarro
  • 2460 Answers
SOURCE: I have a Panasonic cordless
Start by swapping the batteries between units. If the formerly bad handset charges, it's a battery. If not, look for dirty contacts where the unit sets into the base or the batteries fit into the holder.
Carl
Posted on Sep 01, 2008
desertrat144
  • 22 Answers
SOURCE: Panasonic KX-TGA101S all 4 phones will not keep a
From the description, it sound like its time to get new battery packs. Initially just get 1 to make sure the phone chargers are working. If the new pack takes & holds the charge problem solved. Should everything be under the original (or extended) warranty, call the number on the documents to see what you need to do for repairs.
I know this isn't the answer you wanted, but I hope it helps.
Posted on Sep 13, 2009
How can you fix a no screen problem on a Panasonic KX-TGA101S?
Maybe this will help. You can download the manual here:
http://phone.manualsonline.com/manuals/mfg/panasonic/tga101s.html
Panasonic is always helpful when it comes to support for their products so give them a call.
Aug 14, 2014 | Panasonic KX-TGA101S Cordless Handset
Charge does not stay
Could be a battery replacement is necessary, especially if the phone does not stay charged
Jan 29, 2013 | Panasonic KX-TGA101S Cordless Handset
Battery very hot never fully charges [1] next
Try replacing the batteries (think they are 2 AAA's in there)
Feb 28, 2011 | Panasonic KX-TGA101S Cordless Handset
My brand new phone is not getting fully charged. I have put it on charge for even more than 8 hours. The charge bar is still showing very low sign. Additionally it is not getting registered despite...
The set could have been on shelf for a long period and so it is possible that the battery has developed back emf which makes it difficult to charge to the full level.
Also sometimes the set fails to lock on due to the same reason and also if the threshold of voltage does not come up.
Discharge the battery after it has charged a bit and charge again.Allow the battery to be put for charging for over 24 hours. If there is no registering then you must try and see if the warranty on the new phone is applicable as the base and handset could be out of sync..
Feb 05, 2011 | Panasonic KX TG4021 Cordless Phone
Model number KX-TGA101CS not holding a charge. does not pass one bar.
The rechargeable battery, model HHRP107 probably needs replacing. They don't last forever. The link is for information only, you can buy from other sources easily if you wish to do so.
Please take a moment to rate my reply.
Sep 20, 2010 | Panasonic KX-TGA101S Cordless Handset
Sep 13, 2009 | Panasonic Lands Phones
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Panasonic KX-TGA101S Cordless Handset Logo
314 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
