Need to convert propane wall heater to natural gas model cgp18 serial 0813674
Therinnaiguy
  • 1420 Answers
SOURCE: physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Posted on Oct 16, 2007
  • 108 Answers
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
clyde2j2
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
vortash
  • 431 Answers
SOURCE: Rinnai 560PTR Heater Converted Propane To Natural Gas No Ingition
I think you will find the thermocouple or thermostat has gone this allows the gas valve to open and is a saftey device to stop the escape of dangerous fumes .. it looks like a long piece of thin copper wire approx 4mm thick and it extends from the main valve into the pilot light flame .. When the ignition is pushed and you hold your finger on it for a while this tells the the valve that the pilot light is lit .. conduction of heat along this pipe then opperates the diaphram in the valve allowing the gas to the burners the pilot light then ignites them .. if the pilot light goes out the unit will nort run ..
My advice to you is that even though you may be conversant with the heater .. they do tend to have all manner of faults occur when left in storage or if shipped ( jostling and bumping ) is to get a trained gas engineer to check it out it may cost a bit .. but a gas escape and the following reprocussions are far more exspensive and costly .. Also You may not be aware that if you do have an incident your house ,insurance may be null and void if no service documents can be raised for the correct servicing of a fixed or mobile gas Convector .. I hope this helps Regards Vortash
Posted on May 22, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
I brougt glowarm space heater model HDB30PT for propane gas but I needed a natural gas space heater.Can I covert it to natural gas and how can do it for me
I'm sorry to report there is no gas conversion for your DESA heater. In fact, no vent-free (vent-less) gas heating appliance (that includes gas log sets) is approved to be converted from one gas type to another. If you bought it from a retail store, exchange it for a LP Gas Model or a refund.
Hope this answered your question and thanks for choosing FixYa.
Sep 20, 2011 | Desa International GWP20T GLOWARM Wall...
My father died 11 years ago and he bought a Glo-Warm Vented heater for propane gas only. It has never been used as we found it still in its box in an old attack. Can I use this to our natural gas system?...
check on line google make modle serial number btus etc and ask for nat gas converstion kit , age could be the problem here ,or try national energy they are on line or google the makes and ask them direct
Mar 27, 2011 | Heating & Cooling
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Natural Gas To Propane on a model # Vn2000bt
There should be a conversion kit that came with the unit plus installation instructions. If not, then the type of kit you need will be identified in the unit paperwork. You may want to have a technician perform this task if you are unsure in just the slightest. Natural gas and propane use different sized nozzels for dispersing the gas for proper ignition. If not installed properly it could cause incomplete combustion, which = CARBON MONOXIDE = ETERNAL SLEEP. Hope this helps!
Dec 09, 2008 | Desa International GWP20T GLOWARM Wall...
Physical difference between natural & propane orfice
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
