Question about Kenmore 24032\24036 Top Load Washer
Top half of agatator don't turn
15 yr old kenmore washing mach. topr half of agatator does not turn.
  • Kenmore Master
  • 8,220 Answers
Remove the agitator. Place it on the floor. Put your feet on the base and yank the top portion off. Replace these:
top half of agatator don't turn - 124bfd8.jpgPart number 80040 agit dogs(4)
Posted on Jan 06, 2009
Clothes too wet after spin cycle
could be the clutch slipping not releasing the brake allowing it to get upto full speed
Feb 28, 2010 | Kenmore Washing Machines
How do i remove the agatator on a awm593w washer it is leaking grease
I used a tie down strap, I put one hook under the lip of the agatator on one side then the other hook 180 degrees opposite the first, grabbed both straps and lifted it right off the drive bell. Really easy. Good luck Don
Feb 01, 2010 | Speed Queen AWS44NW Top Load Washer
My Kenmove washing maching does not agitate. You
This is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11029852992
which you can go to to see all of the components.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
1. The motor coupler
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:3364003Substitution:285753A $18.50 In stock
may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
If it spins and drains OK, and if you can hear the motor turning, the problem points to the transmission.
Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of them may have either broken or worn out.
moz-screenshot.pngThere is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as for your washer. On it is a list of all of the components and parts for the washer.
By paging down to and following the diagram of the transmission you should be able to determine which actual part is broken.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
When our washer (12 years old) wouldn't spin, rather than spending $170 for a new transmission, we installed a repair kit into the old one ($15) and the problem was solved.
Sep 15, 2009 | Kenmore Washing Machines
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 4025090 washer spins but will not agatate
problem solved ,agitater dogs were broken up inside the agitater hub replaced these and works fine now ,
Dec 10, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
Kenmore 24032\24036 Top Load Washer Logo
111 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
