Question about Frigidaire Washing Machines
Frigidaire Model # LTF2940FS1 won't work repairman cannot fix and techs from Frigidaire don't know what is wrong either
2 mother boards have been replaced. door lock replaced also...still will not work
  • 1294 Answers
SOURCE: F02 error. They came out replaced pump, didn't work.
Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Keep ready a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. No control board nothing.
Posted on Mar 28, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Posted on Dec 02, 2009
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
  • 360 Answers
SOURCE: My mother accidentally pulled the
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Posted on Aug 07, 2011
I have a Maytag Dependable Care Plus washing machine. Water won't fill. The spin cycle works. Repairman out and said there was a short and lose wire. I wanted to know so I could resolve the next time....
Find a repairman who stands behind his work. If no water, I'd first be looking at the screens in water valve and hoses. Could also be lid lock or lid switch depending on model. Could also be defective water valve or possibly defective pressure Switch. Timer could be bad. Many possibilities
Sep 06, 2017 | Washing Machines
My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
May 08, 2012 | Frigidaire Washing Machines
My toshiba PSAgou laptop won't turn on
That is a common problem with the Toshiba. The center pin tends to get broken off. I have had to repair them by either installing a new mother board, or removing the mother boars and soldering in a new power port.
Feb 28, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
I know whats wrong with my tv mitsubishi will not let me order the part or give me the part # for the WD-57734 dlp tv I need to order the lamp ignition circut board because of a short in the board where...
Are you looking for the Ballast for that model? You should be able to google the model number with the word ballast after it and find it with ease.
It is a nasty game where they don't sell parts, just the entire board.
I am here to give you as much help as possible.
SD Tech
Oct 26, 2011 | Televison & Video
Control panel number 4
Hello, There has been a couple times, Frigidaire was sending out the wrong control board in the correct box ( believe it or not it happened to me 2x ).. finally i had to call ELECTROLUX directly and had them send me the board direct to customer.. i believe that the 4 is because there is a wiring issue with one of the microswitches where the damper motor is and it will not allow the damper / control board to recognize "open" position ..I don't know how old your fridge, but in this case you should get a tech out with some testing equipment. Thanks Mike
Oct 23, 2011 | Frigidaire Refrigerators
1.3 year old Frigidaire Stackable washer/dryer model FEX831FS won't drain. Checked pump and hoses. OK. Am in remote Alaska and we don't have service tech's here. Any suggestions.
What you want to check is the lid switch..remove the front panel..on the switch/lid lock asm.will be
the main switch which is part in the black body of the lock asm. the 2 terminals their will have contunuty with zero ohms when lid is closed
when lid closed the white switch will be open and closed when lid open
the one in the black body on the main lock asm. will be open when lid open
IF it does turn out that the lid lock is the problem the part number for it is 134101800
it could be purchased online at;
repairclinic.com
apdepot.com
apwagner.com
searspartsdirect.com
midwestapplianceparts.com
If the switch checks to be good test for power into the drain pump if no power the timer is what is wrong the washer (not dryer) timer is part# 131758600
Gene
Aug 24, 2011 | Frigidaire Washing Machines
FRIGIDAIRE LTF2940FS1 Error Code "PAU"
Hi
PAU is short for pause; the machine detected something wrong so it paused itself. Unplug it from the wall for a minute and plug it back in, it may reset. Once you plug it back in, it should display a Numerical code. You need to find out what's that error code mean.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
