Question about Maxtor Hard Drive
New Maxtor hard drive not seen in My computer
Install a new hardrive using CS jumper settings. The new drive is seen in device manager along with the old (primary) drive but it does not show up in My Computer. Can anyone help? Thanks!
  • 416 Answers
Right Click on My Computer & Click Manage, then click disk mamgment from the left panel. the HDD will show there, since it's a new HDD it must be on RAW state, format from the same console.
Posted on Jan 04, 2009
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Maxtor hard drive settings for a 53073H4
Before doing anything, the user should completely shut down and unplug the computer to prevent electrocution or computer damage. Remove the computer's side panel so that the hard drive is displayed in order to find the jumpers on the IDE drive. Disconnect the power and IDE cables from the hard drive to access the drive better. The hard drive's jumpers are the small, black pegs on the back of the drive. These pegs fit over small metal conductors and assign the IDE drive's role. The user can remove the jumpers by prying them off of their current conductors with his/her fingernails or a small screwdriver. The jumpers can then be relocated to other conductors in order to assign a role to the IDE drive. The user should be very careful while handling the Maxtor jumpers as they are fragile and very important.maxtor-jumper-settings.jpegEach IDE drive model is different but most have three basic settings: Cable Select, Master, and Slave. Each setting is described below.
Cable Select
Cable Select is a Maxtor jumper setting that is the default for virtually all IDE drives. Cable Select allows an IDE drive to naturally become either a Master or Slave depending on the cable used. Cable Select is a neutral setting and is also often used when a user only has one IDE device installed or when a device is neither a Master or a Slave, such as a Floppy Disk drive.
hope this helps
Jun 22, 2012 | Maxtor Hard Drive
Hi, Maxtor 90645D3 hardrive deletion manual jumpersettings.
Basic jumper settings for Maxtor ATA Hard Drives
Thank you for purchasing your new ATA hard drive from Other World Computing! Please
review these jumper settings prior to installing your new hard drive into your computer.
You may want to review more detailed information about the installation process, or
the location and configuration of your existing internal ATA drive before proceeding.
Your manual that came with your computer can be of assistance in both of these
determinations.
A few notes about installing an ATA hard drive into your existing system:
Your existing drive is normally configured one of two ways, Master (single drive), or
Cable Select. You will want to determine this before installing your new drive, the easiest
way is to remove the existing drive from your system and visually inspect it's hard drive
jumpers. Most hard drives have a schematic either silk screened onto the case of the
drive, or the schematic is on a label near the jumper pins. If you have difficulty locating
this information, visit the hard drive manufacturer's website.
If your existing hard drive is configured as "Master", then set your new hard drive
to "Slave". If your existing drive is set for "Cable Select", then set your new drive to
"Cable Select" also. You can change the existing jumper settings on the original drive
to suit your needs, but we recommend following these instructions first to verify proper
operation of the new hard drive.
Installing jumpers on the new drive is a simple process, follow the schematic to
configure your drive.
Please note the configuration of
the internal ATA cable already
installed in your existing system.
If your internal cable is configured
differently than pictured here,
you may want to replace it before
installing a new hard drive to
achieve maximum performance.
For further assistance, visit our tech center at http://eshop.macsales.com/Tech/index.cfm
Mar 10, 2011 | Computers & Internet
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
How do you install another hardrive
Just remove the case, change the new hard drive to slave using the jumper setting (which is Physical), then check in your bios if the hard drive is detected.
Apr 04, 2010 | Gateway GT5692 Desktop Computer
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor Hard Drive Logo
110 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
