2000 Chrysler 300M Logo
Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There isn't any heat coming from the the heater or defog position
I have a 2000 Chrysler 300M and since the cold weather got here the heat/defog isn't doing it's job. The temp. gauge is in the normal position and the fan blow's like it should, but no significant heat. My first guess is the thermostat and can i change it myself.
john berens
Level 2:
  • Expert 173 Answers
  • Posted on Jan 04, 2009
john berens
Expert
Level 2:
Answers
173
Questions
0
Helped
45452
Points
398
CHECK ANTIFREEZE LEVEL FIRST THEN THERMOSTAT
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
ALL I GET IS COLD AIR FROM HEATER. HAVE CHANGED THERMOSTAT, BLED COOLING SYSTEM AND HEATER HOSES GOING TO HEATER CORE ARE BOTH HOT. SOMEONE TOLD ME ACUATOR BUT IT MOVES FROM VENTS TO DEFROST AND FLOOR...
There is also an actuator for temp control. It moves doors in the duct work for heat and for cold air. that is the one that needs replacing. the one you are talking about just moves airflow positions.
Heat blows cold 200 chrysler 300m
Hi Stacy,
There are several things that can cause that. Please read the article at the following link to get a better idea of what needs to be done.
Why Is My Heater Cold?
Chrysler 300m starts at high idle in cold weather
First check the error codes. they can be a lifesaver. Physically look under the hood for cracked or leaky vaccuum hoses. High idling often indicates a vaccuum leak somewhere. look at the vaccuum elbows on both the right and left side of the engine just about midway down the engine from front to back on the plenum- that's the big, black flat assy that channels the air as it goes into the engine.
Once again the codes can tell us alot.
1999 Chrysler 300m heater won't get hot fan blows but doesn't heat
Is there enough anti-freeze in the system?
If so perhaps the system needs bleeding.
On the front of the engine, on top near the big upper hose goose neck and nestled between the runners of the intake manifold is a small nipple that looks like a brake bleeder (10MM). This is a cooling system bleeder, a close cousin to the brake bleeder. When opened it will purge the system of air- likely the culpret you are experiencing. on a cold or just warm engine, this can be slightly opened with a wrench and the air can be "Burped" out. Attach a 1/4" clear hose to the nipple and open the bleeder until you see all the air has left the manifold. (Run the hose into a bucket and dispose of the used anti-freeze properly.)
if that doesn't do it, maybe the thermostat is stuck in the open position. Replace it with a cold engine and use a new gasket each time.
If all else fails, the heater core may be plugged.
3answers
I have an 1999 chrysler 300m an it has an overheating problem. There is also water all over the driver side floor (front n back) it is soaked. It takes about 25mins b4 it starts smoking. Can som1 plz help...
Typically if your leaking coolant inside the car, it indicates your heater core is split and leaking. Replacing the heater core is quite the job. It requires removal of the dash board and heater box. i replaced one in a 97 Cirrus at work last week and it was a 6 hour job. If your not mechanically inclined i would definitley recomend phoneing around for quotes to local auto repair shops and getting it done profesionally.
1999 Chrysler 300M heater is blowing but no heat is coming out. Any ideas?
see if any one mess with it and did something that they should not have
1helpful
No heat in cab.
You did not BLEED the radiator and it's over heating.
Take off radiator cap when engine is COLD
Start engine
Let it idle until it's HOT
As it heats up you will notice air bubbles coming out of the radiator filler neck.
Let car run until you don't see any more bubbles
Fill radiator coolant to keep it topped up to the hot mark.
Put radiator cap back on once you hear the fans kick on.
Done
You should now have tons of heat
Providing your water pump is working
My 2000 chrysler 300m is leaking water from the air conditioner in to floor board the drain line is clear
it is the heater core failing ..not the a/c ....pressure test radiator (cooling system) to be sure ... then R&R heater core...good luck
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
