Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite electric dryer has power but won't start
I have a similar problem but slightly different symptoms. I have power, the 'clean lint filter' light will be on but it is clean and the surrounding area is clean. When I open teh door, it goes out. Maybe this is just a reminder it has to be cleaned every use. I then select a setting and when I press start, just a click. i then press 'pause' to reset it and the same thing happens. Can anyone narrow this down to what may be teh casue?
Thanks!
We just had this happen to us there is a small round fuse ( high limit thermostat)under the heatin element using a voltmeter switch it to ohm and touch the two poles coming of of it after unpluging power cord and wires to the fuse the voltmeter will beep if it is fine if it doesnt beep you need to replace the fuse (hlt) it comes in a kit usually with the hlt and a thermal fuse i think it cost us 25 dollars at local appliance center
Posted on Jan 05, 2009
  • blackburntn Jan 05, 2009
    number one reason for the hlt to pop is a blockage of the exhaust vent our vent tube got crushed between the wall and dryer only allowing a very small amout of air out.
    sorry got the two confused the one under the heating element is the thermal fuse the one on top is the hlt
How to respond to "Clean Lint filter" light.
had similar trouble and it can start a FIRE. Try cleaning the vent outside. The shutter doors can be hindered by lint and critters. If cleaning the vent door is not enough, take vent pipes apart and clean them. This should be smooth aluminum pipe not, the corrugated plastic etc.. If this does not cure it, the blower may be clogged or dead inside your machine.
Mar 05, 2018 | Kenmore Dryers
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
Remove front panel
I have this same problem. The Sears Service Technician just left and said that my main panel needs replaced to a cost of $532.88! Needless to say I will be buying another dryer and it will not be a Kenmore....
Jul 05, 2013 | Kenmore Elite HE4 Electric Dryer
Lint filter put in backwards and won't come out
You will need to pull it out as best you can. What is the model number?
Jan 20, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 592-89047 won't start
Sounds like the lint may have fallen into the fan and has jammed it. The motor will hum if that happens. Its an easy job to clean just take your time taking the blower cover off and reverse the process replacing it.
Apr 26, 2012 | Kenmore Dryers
Kenmore Elite HE want to know where the filter is so it can be cleaned top load, super capacity, have a clean machine cycle, but is there a filter that needs to be cleaned periodically?
most just have a lint filter at front of machine they should be cleaned after every load and chect where dryer vent goes outside wall of house see if it is clogged with lint clean that out as well
Dec 26, 2009 | Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Back outside wall of dryer is burning
hi. thanks for the question . pull dryer away from the wall. remove venting .clean venting to the outside. remove back panel. clean all lint first. cut power to te dryer . try again thanks the appliance doc. positive feed back .thanks the appliance doc
Oct 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
