Question about Panasonic (DMR-ES45VS)
Panasonic DMR-EZ45VEBS error code U80 - Panasonic (DMR-ES45VS)
  • Anonymous Feb 22, 2009
4 Suggested Answers
SOURCE: my dvd recorder DMR-EZ45VEBS COME
I get this too, and a little research brought me lots of anecdotes but nothing concrete, but here's was I deduce from the stories...
The unit has an auto-scan feature that periodically checks for new services or channels. Sometimes when it adds one it encounters and error and hangs showing U80. When you're recording it seems the auto-scan doesn't interrupt, so your program will complete. I've had several failures of timed recordings when the unit has stalled before recording was due to start.
Try switching the auto-scan off...
Functions > Others > Display > New service message
Hoepfully that will resolve it, though you will need to manually scan for new services periodically to make sure you don't miss out. At least you'll be on hand if it fails so it won't sit showing U80 for hours!
Posted on Oct 09, 2008
techbuster
  • 5081 Answers
SOURCE: u80 error code on panasonic dmr-ex75. what is it?
U80 indicates either that poor quality or
damaged discs are being used or that the laser is failing. It is a
self-diagnostic fault code, possibly requiring attention by a qualified
engineer. This is not an inherent fault with the product but a guide for
the engineer to know where, within the product, he should seek the cause of
the problem.
please rate my solution
Posted on Jul 07, 2009
Obertelli
  • 3006 Answers
SOURCE: How do i unlock my panasonic dmr-ez45vebs to play
You need to buy a service remote to do this on your model, but the official service remote costs more than the player and is not sold to the general public.
Alternatively, you can rent a chipped regular remote control which does the same job.
In the UK you can get them from www.multi-region.co.uk
Note that on your model there is no other way to hack the player, it can only be done using the correct remote control.
The remote chips are available separately but are not easy to fit unless you're an experienced electronics technician; you can buy read-chipped remotes but they typically cost the dame as the original player.
I hope that you have found my reply to be of use and only ask in return that you rate my answer.
Posted on Nov 08, 2009
Testimonial: "Thanks for reply"
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
My DMR EX75EB it fails to operate and a code of U81 comes up.
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
The U81 and U80 codes don't mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
Mar 14, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I would like to download the English version of the manual (PDF) for the Panasonic DMR-EZ 45V Video/DVD recorder combo
The manual is available from Panasonic: http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239 . When I fill in the DMR-EZ45V, I got manuals for the DMR-EZ45VEB and DMR-EZ45VEBS.
Additional models are available from the Panasonic UK support site.
I hope this helps.
Jan 04, 2011 | Televison & Video
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I unlock my panasonic DMR-EZ45VEBS to play all region films
Nov 08, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
U80 error code on panasonic dmr-ex75. what is it? how do you fix it.
the problem.
Jul 07, 2009 | Televison & Video
Hi when I turn on my Panasonic DMR-EZ45VEBS I get an error that states 'LD FVU' then the CD slot ejects. It them simply doesnt allow me to do anything. Has anyone experienced this? If so can you help fix...
I get exactly the same problem with my Panasonic EZ48 recorder.
It also displays FM List DL error .It sometimes sorts itself out by holding the on switch for 20 seconds.
Ian
Nov 29, 2008 | Televison & Video
Error U80
Hi all smilerand here, an update
Although my unit had a new drive fitted paid for by panasonic. This did not solve the problem. It turned out to be a back end printed circuit board(PCB), which panasonic paid the costs of.
So this PCB could be the problem with all your units if this is any help
Oct 21, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
My dvd recorder DMR-EZ45VEBS COME UP ERROR CODE U80
Apr 15, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Panasonic (DMR-ES45VS) Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
