Question about Bryant Heating & Cooling
Need size of air filter to model fx4c,fy4a
Can I purchase at Lowe's store
5 Suggested Answers
  • 472 Answers
SOURCE: Bryant furnace model FX4C, FY4A
WELL this could be a couple of problems the reversing valve could be stuck either from not enough pressure which would be a leal and low on freon or the unit is off on low pressure switch/high pressure switch from either being low on freon or something restricting it and caused unit to shut down, ive been a servicer for many years and if it gets below 30 degrees outside i would recommend running the e-heat anyway it does cost more money minute for minute. but you will find it will heat alot faster in those colder nights than the heat pump therefore cost is about the same.
as far as not switching over could be low on freon or a stuck reversing valve... is the outside even running in cool mode if not the you may have a tripped pressure switch...good luck
Posted on Jan 04, 2011
  • 4736 Answers
SOURCE: I need to replace the
If it's a plastic mesh filter, you can buy an uncut kit at most home centers and hardware stores. That you can cut to fit your unit.You'll probably have enough left over to make 2 filters.
Posted on Jul 06, 2011
  • 5129 Answers
SOURCE: My system uses a permenant
The Ruud UBHC-21J18SHG has a nominally 21" cabinet width. So the needed filter is 19.75" x 21" x 0.375" (502 mm x 533 mm x 9.525 mm). The Ruud part number for the filter is 54-23217-03 .
The specifications sheet for the Ruud UBHC series air handlers is available here: http://www.coburns.com/images/PDFs/h22-517rev1.pdf . The filter size information is on page 3 and page 12.
I've found the filter at one online vendor: http://www.patriot-supply.com/products/showitem.cfm/RHEEM_68_101807_03 . (This is a common filter that fits several manufacturer's air handlers.)
I hope this helps.
Posted on Sep 11, 2011
  • 127 Answers
SOURCE: What size air filter fits
Recommend a washable lifetime filter that can be custom fitted for your unit. There are many different brands of cut to fit and custom sized filters available.
The original filters supplied with the unit are usually washable as well although the manufactures are not including it all the time anymore.
Posted on Oct 21, 2011
Need a 10 watt dryer bulb. Where can I purchase a bulb?
Get screw driver,remove screw,then cover,remove bulb and take to lowe's,they have them,10 watt bulbs.
Oct 22, 2012 | Dryers
Can i use only a cold water pipe
You can use only cold water in your washer...if it has a hot water inlet valve on it. It would need to capped off to prevent it from leaking.....a cap could be purchased at Lowe's HomeDepot or any local hardware store just ask for a solid brass cap for a garden hose (same size as a washer hose)
GENE
Sep 06, 2011 | Washing Machines
Need Size for my filter, unit Carrier Model FA4CNC036
I assume the filter goes in at the bottom of the air handler. Carrier, in their infinite wisdom, uses the oddest sizes of any units. Use a tape measure and measure the depth and width of the opening.
It may be something like 19-5/8x21. You can't buy these off the shelf at home supply stores.
You will have to find a heating and air supply store to get them.
Hope this helps.
Sep 03, 2011 | Heating & Cooling
What size air filter fits model #UBHC14J06SFD? I was told by a tech that the original filter that came with the unit needs to be replaced. This was purchased back in 2004. The sizes that are sold in the...
Aug 21, 2011 | Ruud UBHC Air Conditioner
I have a refrigerator model #GD5PHAXMS10 icemaker that stopped working about two and a half weeks ago. At that time the water the water works dispenser worked like normal. Today the water dispenser...
The first thing to do if you already haven't is replace the filter,it's in the grill/kickplate below the freezer door. If you have relpaced filter,need to pull refrig from wall and check that their is good water pressure from house plumbing,if it is good the water valve the sends water to icemaker&door dispenser when water is called for is going to be the problem.The part # for that valve is 4389177 it could be purchased at your local appliance parts store on oline at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
The filter BUT NOT the water valve could be purchased locally at Sears,Lowe's or Home Depot
I hope this helps you to diagnose your icemaker/dispenser
Gene
Aug 07, 2011 | Refrigerators
We need a replacement filter for our Sharp Air Conditioner Model AF - S60DX.
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Sharp AF-S60DX Air Conditioner
I need to replace the air filter on this unit and I can't find the right size filter. What size do I need? I ave an Armstrong model # 64HWC303a-2B Serial # 8401H12194
Jul 06, 2011 | Heating & Cooling
Need to buy a handle light for weber family 300
Weber doesn't have a handle light for the 'Q' Model grills. But, you can purchase a generic clamp-on handle light from just about any home center (ie.Lowe's & Home Depot) or hardware store (Ace or True Value) that sells gas grills and accessories.
Hope this helped you. Please let me know. Thanks and Happy Grilling!!
May 16, 2011 | Weber Q300 Grill
Bryant furnace model FX4C, FY4A with heat pump and a/c will not switch from a/c to heat pump. Only have heat with emergency heat on.
Jan 04, 2011 | Bryant Heating & Cooling
Where can i purchase filter for a york furnace affinity yp9c080c116mp11? looks like 20x25x5 accordian type. Home depot--lowe's. What is the model number?
you should be able to find that filter size at either store if not search air bear that should get you thte right size filter
Jun 12, 2010 | Heating & Cooling
Heating & Cooling Logo
405 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
