Question about Home
My shower head won't rotate - Home
2 Suggested Answers
muralme
  • 20 Answers
SOURCE: How to disconnect from shower head - stop male connection from tu
Two pair of channel lock
Posted on Jul 30, 2009
Shower won't work
Sounds like calcium build up. remove the shower head and clean calcium or replace the shower head. Let me know if this helped.
May 12, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
Delta handle won't turn more than half way
Take the handle off and adjust the hot temperature stop. Its just a plastic piece that needs to be adjusted up more. It just fits in grooves like a gear. Its easy to do.
Apr 19, 2013 | Delta & Single Handle Shower Faucet
System won't switch to shower
You need a diverter in your spout. The spout will screw off and the new one will screw on. Lift the ball while the water is running and it will divert the water to the shower.
Dec 14, 2012 | American Standard One Handle Tub & Shower...
Why do I only have hot water in the shower
sounds like either the cold water that feeds the other half got shut off, or the mixer in the valve for controlling the water temperature is broken....most likely the water got shut off. better go to the water source and trace the cold water feed pipe ,looking for a shut off valve....it could also be behind the shower panel, then turn or rotate the valve the other way and go test the water to see if you can adjust the temperature now.....if not, then replace your hardware.......in the mean time, you could turn the temperature down on the water heater so that you won't scald yourself in the shower til you have time to fix it properly.
Apr 26, 2012 | Moen Home
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Nov 12, 2010 | American Standard One Handle Shower Only...
How to open shower head ?
Just rotate the head in anti clockwise
Aug 21, 2010 | Water Pik Shower Head
How do i adjust the spray type? the shower heads dont turn or anything to adjust spray type. how is this adjusted?
If you grab a hold of the head itself you then rotate that either way to adjust the spray,,Hope this is helpfull
May 04, 2009 | Peerless Industries Peerless 76410WH...
Home Logo
104 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
