What does F6 mean on a westinghouse 18000 btu split unit
Fan spins slow
SOURCE: Split Unit Spitting water
Do you live in an area of high humidity? This could be your problem. The water that is coming off the evaporator and draining to the outside pan is building up and picked up by the condensor fan and consequently blown by the fan inside. If this is the problem the fix is to drill a hole in the pan to permit the water to drain from the pan. Be careful as to where the hole is drilled so as to not damage any component of the a/c. I would suggest at least a 1/4 inch drill bit be used to make the hole.
Posted on May 26, 2008
  • 1250 Answers
SOURCE: need a fan motor for fedders model A6Y18F7B 18000
Easiest thing to do is pull the motor out and take it to Grainger. They can probably match it with a Dayton brand. No HVAC place will sell you a motor. They are all wholesale, and not to the public. You really don't have a whole lot of options here.
Good Luck
Posted on Feb 21, 2009
pierre1811
  • 144 Answers
SOURCE: how to insert oil in outdoor of split type airconditioner
You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly.
Posted on Feb 24, 2009
SOURCE: Wiring diagram for Ramsond 18000 BTU Ductless
See link below for detailed wiring. I found it very helpful
http://www.ramsond.com/minisplit/wiring/detailedwire5170.pdf
Posted on Oct 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: the best pressure of gas in a split ac in
Should be around 70 psi on the low suction side if R22 is being used.
Suggest you read up on Superheat and Subcooling.
Posted on Jun 05, 2010
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
How to start air conditioner in f6 mode
i need assistant , when i on my ac .after 1minute it shows f6 and off
Apr 17, 2012 | Heating & Cooling
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Installed 18000 btu split system heat pump and condensing unit is freezing up in cold weather 15 degrees out side air.
Actuall, out door fan sucks fresh air to cool the condensor when it's on "Cool" mode. If it is in " Heat mode' if the fan should run only on pressure build up. May be pressure switch is faulty.
Melt the ice with Torch gun, and check again.
Dec 15, 2010 | LG Heating & Cooling
Liquid line freesing up
Check your air filters first and the indoor coil to make sure it isn't coated with dust and lint. Then make sure the indoor fan is running while the unit is trying to cool the house. If all that is good then you probably need to get the refrigerant charge checked.
Jun 07, 2010 | Haier HSU18VCA 18000 BTU Cooling Only Mini...
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
