Question about Yamaha Music
Psr 8000 no sound right speakers
No sound from right hand speakers, headphones OK
2 Suggested Answers
  • 1138 Answers
SOURCE: peavey minx 110 no sound from main speaker but
Inside the headphone jack is a built in switching mechanism. It is there to cut off the sound to the speaker when you are using headphones to practice quietly. For some reason or another it seems as if this is no longer working correctly. One of the causes of this can be bad solder joints on the circuit board where this jack is located. Another cause is a failure of the jack itself. If you are capable, Take the circuit board out and have a look. Hope this helps.
Posted on Oct 27, 2009
PSR 2000 no power
Too many possibilities. That is why there are audio technicians. Is it plugged in, is the cord good, is the on/off switch good. Then is the speaker ok? Could be a fuse or even the outputs. Sorry this problem can not be solved without hands on.
Jan 29, 2018 | Music
Yamaha psr-gx76 keyboard-sound comes through headphones. Does not come through speakers.
Try cleaning the headphone jack. If that doesn't help, it'll be the amplifier board and will need to go to the shop.
Aug 14, 2015 | Yamaha Music
Yamaha psr 300
I'd suspect power supply first - filter capacitors may have leaked/dried out. That would be an easy fix for someone familiar.
Mar 05, 2014 | Yamaha Full-Size Keyboard
The keyboard is showing sign of power input but the screen is not lighting and produces no sound
1. Try the volume
2. Your adapter may not be the proper voltage/amperage. If the adapter has ratings listed, make sure they match the keyboards ratings.
3. Try it with the headphones. If they work and the speakers don't, you've narrowed down your problem. There may be some damage or wiring problem within where the board meets the speakers, and/or before processing.
4. Try it with batteries. If that works, you need a new adapter.
http://www.ioffer.com/i/adaptor-cord-yamaha-psr-or700-s500-s700-s900-arranger-113553507
Feb 06, 2011 | Yamaha PSR-S500 Digital Keyboard
Yamaha PSR-27; NO SOUND
If it is very old, check if the volume control could be contaminated. Make sure a voice is selected via the buttons.
Do try the headphones before anything further.
Jan 20, 2010 | Yamaha Music
Peavey minx 110 no sound from main speaker but headphone jack is ok. speaker wires are attached ok.everything on the board appears to be in good shape.amp powers up and all controls work great through...
Oct 27, 2009 | Music
No volume at all out of speakers PSR-E203. Plugged in to AC supply. Yamaha Portatone PSR-E203 YPT-200
Make sure you use correct power supply.
Try headphones. If they work, then the switch on the headphone jack that disconnects the speakers may not be working properly and not connecting the speakers.
Oct 13, 2009 | Yamaha Music
PSR-2100 need to find replacement circuit board.
I don't have a parts source for these other than Yamaha. Call them up to get the part number for the board. The sound is usually sent through the headphone jack which acts as a switch when you use headphones. Replacing that board should resolve your problem. If the board is no longer available, it is possible to repair the existing one, but this is a specialty task and not one I would recommend a novice attempt.
Please keep us posted on your progress,
Dan
Jul 24, 2009 | Yamaha Music
Music Logo
23 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
