Question about Home Security
How do i reprogram the kep pad on a genie h-6000-07 garage door opener
pgh_pa_guy
  • 2992 Answers
SOURCE: craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Posted on Feb 13, 2009
whirlwindsys
  • 18 Answers
SOURCE: reprogram key pad for garage door opener
To program the keypad, you will have to press the LEARN button on the back of the garage door opener console and when it begins to flash, enter a new 4 digit code on your keypad and press enter. You should hear a click and see the lights on the opener flash.
Posted on Feb 18, 2009
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 3197 Answers
SOURCE: Trying to clear the codes from my Garage Door
In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
Posted on Mar 29, 2010
  • 3197 Answers
SOURCE: Can't reprogram/operate keyless entry pad for
If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Posted on Apr 07, 2010
Testimonial: "Bless you....thanks so much... its working, yea."
How do I reset a password for a genie pad on garage?
try this:
http://homeappliance.manualsonline.com/manuals/mfg/genie/sd9500_9.html?p=1
Nov 24, 2015 | Building Materials
I have a Genie Directlift 2060 garage opener. My wireless keypad has always worked fine until now. I enter the code and nothing happens. I replaced the battery with the same result. I followed the...
Your wireless keypad may be flashing the red light to falsely assure you that it is working when, in fact, it is not. Another possibility is that the receiver has failed.
Oct 21, 2013 | Sears Craftsman LiftMaster Chamberlain...
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
Can Genie Wireless Keypad work for door w/o LEARN button?
If the keypad doesn't have dip switches it will not work with that opener.
Jun 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hummer H3 ReProgram Garage Door Opener forOLD Genie
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Jun 02, 2009 | 2007 Hummer H3X
Home Security Logo
468 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
