Question about GE Profile Spacemaker Over-the-Range Microwave
Vent boost light buttons broken
The vent, boost, and light buttons have pushed into the microwave and no longer work. How do I remove the faceplate and switch?
  • chrisg007 Jan 21, 2009
    I was able to remove the faceplate today by using a small screwdriver. If you look underneath the switches, there are two thin metal strips that wrap around to keep the faceplate on. By inserting the small metal screwdriver, you can bend the strips so that the lower part of the faceplate detaches. To remove the upper part, remove the two screws visible on the top of the microwave and remove the vent piece. Once you have done this, it's easy to remove the entire faceplate. Now I am wondering which part to order to replace the switch and faceplate. If you find out, please post.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you.
MicrowaveSvc
  • 9098 Answers
SOURCE: Vent fan noise
I'd say the bearings are getting dry. I'd hit it with a a drop of 3-in-1 oil or sewing machine oil. If you don't have the owner's manual, you can download one here: http://www.geappliances.com/service_and_support/literature/ It's also possible that the keeper which holds the fan blade assembly may be broken or loose. That could cause the fan to slip and rub. Either way it will have to be disassembled to a degree, probably starting with removal of the grille. Exploded views of this model may be helpful. They can be found at this site: http://www.geappliances.com/shop/prts/ Under 1 select "Repair Part", under 2 select "Microwave" and click "Go". A window will pop up and you'll enter your (complete) model number. Good luck.
Posted on Nov 07, 2006
  • 6 Answers
SOURCE: Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Posted on Jan 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: can i install an external blower outside to boost
Possibly so.
I'd first check to be sure the grease filter is clean, the duct work is not clogged, and the outside vent is not home to an animal's nest.
You can download GE owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Jan 11, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
Posted on May 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a GE microwave # JVM2070SK02 that the
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 22, 2010
I have a GE Space maker 2.0 model JVM2070SK02 that has three buttons on the lower right vent, boost and light. The light button is pushed up into the microwave. I think there must be a spring behind the...
Remove the top grill and on top of the control panel is (1) screw, remove that and gently tap up the control panel to release the panel from the microwave front cabinet. Now as I researched this model, the buttons are part of the panel and are attached to the panel directly. Up may want to replace the microwave as the price is high to replace the panel. Part number is WB07X10972, Good Luck and be safe and unplug this unit before removing this panel.
Nov 16, 2014 | Microwave Ovens
What do I do when the vent won't turn off?
unplug it for 12 hours or more and try again. Failing that the button or circuit for it may be broken, also make sure nothing is blocking the vent or nothing in the vent assembly is damaged. if you are opening the microwave make sure you know what you are doing of get a pro to do it for you. get an estimate and compare that to the price of a new one. Especially if the microwave is old or cheap.
Nov 29, 2017 | Kenmore Microwave Ovens
Vent, Boost, Light buttons pushed in - not working
They may be available as a unit--two or more and will either be melted into place or secured with screws etc.
May not be a easy part to find or see if it is even sold as a part.
Dec 12, 2012 | GE Microwave Ovens
The fan, vent, light and clear button no longer
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
May 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with light,vent, and the boost
Depends on the model #. I dont see it on here. This unit may have some kind of button assy that has broken and fell back into control panel.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker 2.0 - black buttons on panel for vent, boost, and light broke . Any way to replace the buttons and take the panel off?
I had the same problem. The front plate is tabbed into place and removes with a flat tip screwdriver and prying in various spots to pop out the tabs. Once the front stainless plate comes off, you need to get behind the black buttons. There is a circuit board behind the buttons, which they make contact with. The problem with mine was the circuit board pushed beyond two metal tabs that keep it in place, so that the buttons were unable to make contact. I used a curved tool to pull the circuit board back forward in front of the tabs and into place. I put the front plate back on and it works like a champ.
Oct 28, 2009 | GE Profile Spacemaker Over-the-Range...
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
166 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
