Question about Philips 190B6CB/27 19" LCD
OSD Brightness on screen constantly
OSD Control = (OK) inoperative and brightness constantly random cycling from 0 to 100. Screen brightness corresponds to control display
  • mnellis Jan 27, 2009
    The brightness is on and WILL NOT GO AWAY. I have unplugged my monitor but it just comes back on?
  • 25 Answers
Pls change the contorl buttons ( no 4 )
Posted on Jan 04, 2009
  • sparksflynz Sep 09, 2011
    I found that one of the brightness buttons, in my case the up, was sticking. I grabbed a pen and whacked this button a few times till it became unstuck then was able to press the ok button which removed the box
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Adjust screen brightness
Press the OSD ("On Screen Display") button on the bottom-front of the monitor. Use the other nearby buttons to "navigate" through all the settings, to select "Brightness", and to move the level UP/DOWN.
Wait a few seconds, and the OSD will vanish, by itself.
May 13, 2010 | LG Flatron L1750S 17" LCD Monitor
Black screen (Philips 190G)
check the brightness / contrast control
do you see OSD (On Screen Display) Menu clearly?
Feb 08, 2010 | Philips 190B6CB/27 19" LCD
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
Too Bright
It could.Check the screen voltage G2,If its high more then 400v this fix could work.
Samir
Mar 09, 2008 | Dell P1130 21" CRT Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Philips 190B6CB/27 19" LCD Logo
779 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
