Question about Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi DLP WD-65C9 and Your Status Light is Blinking yellow
  • 375 Answers
SOURCE: Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Posted on Sep 12, 2007
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
I HAVE A MITSUBISHI MODEL 65C9 THAT WHEN I PRESS POWER BUTTON AND GREEN LIGHT BLINKS STARTS TO LOAD UP AND THEN TURNS OFF WHAT IS THE PROBLEM?
You need to replace the main board, call Mitsubishi help line, they did not charge me a dime (If your TV is less than Yr old)
May 17, 2010 | Mitsubishi WD-65C9 65" DLP HDTV
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Oct 13, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green status light keeps blinking after lamp replacement
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-65C9 65" DLP HDTV Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
