Question about Bosch Ovens
I cant unscrew the glass light bulb cover in my Bosch oven
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: Can't remove the oven light cover to change the bulb
clean it with wd40
Posted on Jun 30, 2009
protek480
  • 1723 Answers
SOURCE: how to change the oven light bulb in a candy f245
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Posted on Jul 15, 2009
Testimonial: "Spot on - I actually used insulating tape and water pump pliers- but I needed to know it would be ok."
barkencoa
  • 3463 Answers
SOURCE: I have recently moved into a Park Home that has a
If it has not been removed for a long time, then it could be stuck with bunt on grease and fat.If it is a round glass, then it should unscrew anti-clockwise.
Try wrapping a cloth round a pair of grips, and try to unscrew it that way.
Do not put too much pressure on, as you may break the glass.
Posted on Feb 08, 2010
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
Have a Bosch built in Oven, cannot release glass cover to replace oven bulb
Take a look at www.espares.co,uk where they have some videos explaining the different fittings....
On some the glass cover unscrews and on others there is a screw and cover plate that needs to be removed..
Apr 16, 2017 | Bosch Ovens
How to unscrew bulb cover in AEG oven? Glass cover won't move!
spray with oven cleaner leave for a day then try again
Apr 30, 2015 | AEG Ovens
Where is the lightbulb In the oven and how do I change it?
Hard to give you exact location with brand or model number but here is what you look for. Open the oven door and with a flashlight look over the top and back wall of the inside liner. The light bulb is usually located behind a clear glass round cover. The cover may have a wire retainer across the middle of it to hold the glass. If it does, just flip or push the wire to the side and the glass cover will come loose. Unscrew bulb to replace. If no wire retainer, then there could be a metal plate with screws holding the glass in place. last type would be that the glass itself unscrews to get to the bulb.
Apr 02, 2015 | Ovens
How i can change the lamp in my Bosch oven?
Remove the glass cover and unscrew the bulb.
Dec 04, 2014 | Ovens
I have a Bosch HBN double oven unit. The bulb in the lower oven has broken with the screw-in base of the bulb stuck. The glass top of the bulb has come away. Cannot get the remaining bit unscrewed due to...
If you try using a thin NOSE PLIER - with a n ALIGATOR MOUTH- it will be easy to pull out by unscrewing the stuck up damaged thread of the bulb. Once it i s free even with a higly pointed screwdriver it can be pushed to unscrew.
Please try this out and it will be easy to replace.
Aug 19, 2011 | Bosch Ovens
How to change the light bulb
unscrew cover glass to gain access to bulb it unscrews normal thread very easy if glass stiff heat up oven for a few minutes and try again
Dec 10, 2009 | Neff B1421 Electric Single Oven
Glass light cover removal
Try spraying WD40 onto the glass and bulb holder, try to screw the bulb cover back on first, and then try to unscrew i, it may help if you grasp it with a cloth or similar as you try to unscrew it
Plz rate my solution.
Tghanks.
Jan 19, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
Ovens Logo
26 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
