Question about BenQ FP91G+ (Black)
Can not diaplay when connected to external TV tuner Box(fontech)
The monitor goes blank when the Box is powered. The audio comes rite but the monitor goes blank. We have connected through VGA input that the monitor has. it wa working fine withthe CRT monitor the i was using previously.. pleas help me wt to do???
  • Ram sumanth Jun 05, 2007
    The box is a Exteral TV tunner card. Fontech make.
    The monitor goes back as if it is off.
    Genius:
  • 2,985 Answers
'The Monitor goes blank when the box is powered' what does that mean exactly? what box? What was the monitor doing before the said box was pwered?
Posted on Jun 04, 2007
  • john ash
    john ash Jun 05, 2007
    Meaning a USB connected?
    1. Remove the tuner software-reboot - make sure you are offline-disable the anti virus ware- re install the software.
    2. disconnect all other USB devices when not in actual use. Having a string of USB devices reduces the power available through the PSU.
    connect only those you need to run the machine. connect others on an as and when basis, making sure only the bare requirement in connected at any one time.
    Make sure you do have a good aerial
    Come back
Which external tv tuner will work for SONY kv-xf21m80 model
To by pass the tuner use a cable, satellite or other box that has its own tuner--use the audio/video outputs the box must have and connect to a similar INPUT on the TV---leave set on that input and change channels with the box used.
Dec 23, 2012 | Televison & Video
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
Humming noise through Tv speakers. Goes away if I mute sound?
If the noise is coming in through the onboard tuner then repair may the only option. If you have a DVD or VCR and can connect the line level inputs (look like stereo connections) then do so and use that input, if the sound persists there then it is likely the audio circuitry - also a repair item.
Bypassing the TV sound system involves connecting your cable box, DVD or VCR (using the tuner from that unit select channels) audio output to a stereo system and then the TV becomes a big monitor (picture only)
Jan 03, 2010 | Polaroid FLM-3732 Television
I want odyssey 501tv tuner internal driver software
i suggest u try the external TV tuner box...as those do not require any driver...not any installation of software...also it does not require ur computer to work...just ur monitor to be ON...
just connect ur monitor and computer thur the external TV tuner box and connect the TV cable to the tuner box...
Dec 23, 2009 | Computers & Internet
Tv problem
Since the NEC is not a TV but a monitor, it does not have a tuner nor speakers that it why it has no RF input. So if you want to watch TV on it you need a cable box with an HDMI and an audio out, and a pair of amplifed speakers. You can use the cable box's universal remote to turn your monitor on and off.
To get TV video, get an HDMI-to-component video (red/blue/green) cable then to get audio connect the cable box's red/white RCA audio out with an inexpensive set/pair of amplified PC speakers. For this you need a 3.5mm-to-RCA adapter to hook these up properly.
Because the audio is coming from independently powered speakers, it will be nice to have a set that goes on standby when there is no audio signal from the cable box. This would eliminate the need for you to stand up and power off the speakers when you have shut down your TV (monitor) and cable box. Or even better, get one that has a remote so that you can raise or lower the volume or power off as needed.
Hope that helps.
Aug 28, 2009 | NEC 42 in. EDTV-Ready Plasma TV
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Tv tuner card is not supporting with lcd monitor
The intex it 3488 tv tuner has known compatibility problems with this particular Acer monitor: see here.
If the tuner card is new see if you can get a refund, by claiming it as faulty, after all this is a factory fault.
Sep 08, 2008 | Acer AL1916W 19" LCD Monitor
BenQ FP91G+ (Black) Logo
169 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
