Question about Car Audio & Video
Is there fuses located inside the car of a 99 deville.. I was installing a car stereo and must have blown a fuse.
    Novelist:
  • 146 Answers
Look underneath the dash area under the steering wheel. Most cars have a fuse panel there. There may also be one under the hood near the battery.
Good luck
Posted on Jan 04, 2009
I was hooking up a stero in my 2000 cadillic deville when a spark occured now the system is completely dead
Afternoon, the stereo has a fuse, which has blown. They are usually found on the positive side of the wire for the main power to stereo , if not that one, it is the fuse inside it. The ones I have fixed are very tiny, not standard size. Next time, disconnect the battery or put tape over the ends of the wires. good luck. You are not the first to do this and you certainly will not be the last so do not feel too bad. (Australia)
Jan 15, 2012 | 2000 Cadillac DeVille
I have a 99 deville went to car wash and afterwards windshield wipers stopped working. Fuse was blown but when I replaced the new fuse blew when put in ???
there"s a black steering wheel cover under the hood try tapping it real good and it should come back on if its not the fuse's
Sep 13, 2011 | 1999 Cadillac DeVille
My 1999 DeVille Concours A/C and heater fans don't come on.
open hood,look in main fuse box for blown fuses,or bad relays to heater fans. the a/c fan should come on only when you turn a/c on at the dash panel only. it has nothing to do with the heat. if the heater blower fans don't come on, then look in the main box[fuse] for a blown fuse also. otherwise the problem is in the heater control module.[where you turn on a/c and the heat] that panel has a different fuse location.under the dash drivers side or on panel on drivers door at the door jam[where the door shuts towards the front of car,under mirror,but inside] look for fuse panel there also for blown fuse. hope this helps,but if not,recommend you seek a pro.such as cadillac
Dec 28, 2010 | 1999 Cadillac DeVille
Gas cap door on 99 deville wont open
It's either the fuse is blown. Or thIf this was at all helpful, please rate. Thanks for asking.e fuse is blown from a short in the wiring.
Jun 29, 2010 | 1999 Cadillac DeVille
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
Leveling system not working. Is there a fuse i can check if so where.
INSIDE THE ENGINE COMPARTMENT THERE IS A FUSE LOCATED NEAR THE PUMP IT'S AN INLINE FUSE TRY CHECKING THAT FUSE IT IT'S BLOWN REPLACE IT.
Aug 20, 2009 | 2002 Cadillac Deville
1993 deville 4.9 v8 door lock lights stay on and battery dies.
switch in door ?? recycle this beast for three small cars like a citreon C3 or a polo or something 5 litres of gas burning CO2 pollution ??horrendous
Mar 31, 2009 | 1993 Cadillac DeVille
Car stereo help
There are some tests you can perform for checking the stereo. Yes, you are right, there is a yellow and red wire. Yellow constant power, red is switched throught the ignition. During the installation, you may have blown a fuse. A bigger fuse is not needed, stick with the same size if you find a bad fuse. Hook the red and yellow wire together for TESTING PURPOSES to one or the other of the hot wires in the vehicle. This will also test to see if you have a bad fuse. If the stereo powers up in one or the other power connections in the car and works, you have a blown fuse. I have seen some fuses be located under the hood of the car near the car battery. Hope this helps, Bob
Oct 29, 2008 | Car Audio & Video
99 ford excort with no ac
the only thing that might hapen you blown a fuses put the ac on open the hood look at the ac compressor look if the ac clucht that the front of compressor if it turn if it turn go inside does the blower motor work fan inside of car work if the fan doent work and the ac clucht burn fuses or on the passager side under the dash the blower motor is there lots of time the resistor burn on those check it out let me know
THANKS FOR USING FIXYA
PIERRE
Feb 22, 2008 | Car Audio & Video
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
