Question about Nortel Networks M5216 Phone
The transfer button on my nortel M5216 doesn't work anymore
When i press it, a 'p' appears on the display and nothing happens. I recently tried to move the phone and then put it back where it originally was
3 Suggested Answers
SOURCE: We have a Nortel T7316E & want to transfer live calls to cell
transfer (under screen when on a call) is for internal transfer. you need the external transfer feature from your phone company, then a "link" key programmed on your phone. link is also feature 71. when on a call you hit link or feature 71, then dial the cell or have speed dial buttons for them,.
Posted on Apr 22, 2010
SOURCE: i need to be able to transfer incomeing calls to a
Bit late now haha, but this website might help http://www.cgt.co.cr/site/manuales/ip_lip_7016d-24d.pdf
Posted on Nov 11, 2011
How do I program numbers in Nortel Meridian M5216 Centrex
See page 16 of the document below, however whether that works depends on how the centrex system is programmed.
http://www.bu.edu/tech/files/2009/09/M5216userguide.pdf
Jul 22, 2014 | Nortel Lands Phones
M3903 - no dial tone
Unplug the phone from both the line and power adapter. Let it set for at least a couple of minutes. You may have activated call forwarding - all accidentally, if that happened the problem will be in the electronic exchange, not the phone. Find out what the "cancel call forwarding" code is for your system....
Apr 10, 2013 | Nortel Meridian M3903 Phone - CHARCOAL
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
SIR HOW TO RESET TRANSFER BELT,IMAGING UNIT, FUSER UNIT FOR SAMSUNG CLP 510
You can check the level of each item.
1. In ready mode press the Menu button on the control panel everal times until you see 'Setup 'on the bottom line
of the display.
2 Press the Enter button to access the menu.
3 Press the scroll button until 'Maintenance ' displays on the bottom line.
4 Press the Enter button
5 When 'Check Others ' displays on the bottom line,,press the Enter button .
6 Press the scroll button until the item you want to check displays on the bottom line.
7 Press the Enter button The display shows the percentage of item.
8. Press the scroll button display either 'Image Count' or 'Reset'
9a. Choose 'Reset' and press enter to reset the counter after replacing a consumable item
or
9b Choose Image count to display the counter.
10. Press the Upper Level button to return to step 7 and select a different choice or press it a second time to return to step
6 and choose a different item.
11. To return to the Ready condition press the Upper Level button several times until 'Ready' appears in the display.
Aug 23, 2011 | Samsung CLP-510 Laser Printer
I'm having trouble transfering calls on my Norton IP 1140E. Every now and then when I take a call, the 'transfer' label hops over to a different button and I'm completely unable to transfer...
Hello, depending on the status of the call the buttons will change automatically. Be aware that you may not be the initiator of the call so you may not have all the features. I hope this helps. If not you may contact me at: http://www.liveperson.com/nortel-guy
Jul 28, 2011 | Nortel 1140E
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Nortel Networks M5216 Phone Logo
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
