Question about Frigidaire GLER642A Electric Dryer
Frigidaire Dryer How do I connect the silver hose to the back of the dryer? I just moved and the washer/dryer have been in storage for years so I no longer have the manual
    Problem Solver:
  • 11 Answers
All you need is 2 large pipe type clamps and use them on each end, any home improvement store should have them. hope this helps
Posted on May 20, 2007
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaier dryer just moved trying to attach dryer vent to back of dryer. only has opening. am i missing a tube that should be there to attach hose to?
Yes their should be a tube that sticks out of the back about 6-8 inches the vent is connected to.The part number for that tube is 131451600 it could be purchased atyour local appliance parts store or it could be ordered online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
to replace that tube the entire dryer must be disassambled to get to the blower housing to connect
Aug 28, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLGT1031CS1 washer timer
Yes. Replace the timer and you are good to go.
Jul 05, 2010 | Frigidaire GLGT1031C Dryer
I need to remove and replace a washer drain hose on a frigidaire combination washer/dryer.
if the conection is not on the back of the washer than you will nead to remove the two screw's at the bottom of the frount panal,remove the panal and you should see the drain line on the left side in the backmake sure you have somthing to catch the water befor you remove the clamp holding drain hose on.
Nov 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Keep the dryer from moving around on the washer
It may be bolts loose in the back where Over Under washer/dryers are connected.
Good Luck!
Jan 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer and Dryer
there will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
Dec 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLER642A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
