Question about Dell E200 233Mhz Thin Client Terminal System (GXL/32Mb/Win Ce 2 901995-17 (90199517) Network Terminal
I have just come into possession of 5 e200 w/out power cord.
I am trying to find the proper powercord/ac adapter to replace the missing ones on my new e200's. I searched Dell.com and found very little besides the manual which does not have the item number. Does anyone use a generic ac adapter, and if so what is it?
I found the following description of the power brick:
here some information about power brick :
3 4
o o
2o o1 shield: negative
^(notch) 1 & 4 : +5V
2 &3 : NC (not connected)
I retrieved the information from the following Forum discussion:
http://www.linux-hacker.net/cgi-bin/UltraBoard/UltraBoard.pl?Action=ShowPost&Board=ThinClient&Post=4&Idle=0&Sort=0&Order=Ascend&Page=0&Session=
Posted on Nov 09, 2007
    Genius:
  • 2,985 Answers
If it is NEW that is from the factory as opposed to new to you it should come with out a power cord or power adaptor. A good guess is if it is externally powered it will want a 12 volt supply. One way of finding out is to examine carefully the the power input socket. If it is a small co-axial one with a square in square symbol with an indication witch is the 'live' pole then it is a low voltage from an external supply. This being so- a Universal stabilized power supply should do it. These come with a slider switch for various voltages, and a strip of connectors also colour coded at the tip. Also the various sizes match various voltages this means that one connector one voltage. So when you have got a supply pack take a connector on its own not attached to the cord and offer it to the power input. The one that fits is the one you want - so select the voltage to the appropriate colour. It is possible it may not work All you have to do then is unplug the connector from the cord and reverse the polarity.
Posted on May 26, 2007
  • john ash
    john ash May 26, 2007
    You asked what is it - the power supply is a common universal one found in most electrrical stores
    I got mine in ASDA[Wallmart in US] about$5-7 or so
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
I misplaced my power cord to my notebook. How do I determine which powercord is the ccorrect one?
A) Look on the bottom of the notebook. Usually states the Voltage (V) and Amperage (A)
Should state > Input: 18.5V/3.5A
(18.5 Volts at 3.5 Amp's)
B) Look at the charger;
The AC adapter (Charger) will state;
Input: 100 ~ 240V/50 ~ 60Hz
Output: 18.5V - 3.5A
Should look similar to this,
http://www.buy.com/prod/65w-new-ac-power-adapter-charger-cord-for-hp-compaq-presario-c300-c500/q/sellerid/24353325/loc/101/213887466.html
Nov 29, 2010 | Compaq Presario 700 470024-192 Notebook
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
The WII does not turn on, what do I check to fix it?
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Hope that helps!
Aug 12, 2009 | Nintendo Wii Console
Powercord
Most radio shacks will have power cords
Jan 31, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
Lost powercord
Go to www.sears.com the parts dept have make and model ready!
Thank you for useing us!
Dec 13, 2008 | TruTech PVS12701 Portable DVD Player
Cord missing
http://www.18002526123.com/products.aspx?type=pa&view=104&p=34&sc=6
Apr 15, 2008 | kawasaki PVS1965 Portable DVD Player
KDS RAD-5 monitor set up
THE POWER SUPPLY PLUGS INTO A WIRE STICKING OUT OF THE END THAT PLUGS INTO THE COMPUTER
Apr 15, 2008 | KDS RAD-5GS 15" Flat Panel LCD Monitor
Durabrand Portable DVD w/dual Screen
http://www.unitedsale.com/product_info.php?products_id=17976 This link is for an Audiovox DVD player, but it may fit yours or else you can cut off the plug on your existing power adapter and reconnect it to this one. Also try searching Google for "AC adapter 9V 3A".
Apr 17, 2007 | Durabrand Portable DVD
Computers & Internet Logo
345 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
