Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Heater won't work below 0 degrees farenheit
The heater works fine in the garage above 0 but when i try to use it outside the temp display will flash "CC" and then shut off and the voltage light will flash i used my shortest cord but made no difference on the light but if i pull it back in the garage it will work for hours
    Problem Solver:
  • 6 Answers
Unfortunately this was a firmware bug in the early models. The "CC" is simply indicating that the temperature reading is under 0 degrees. The actual problem is that the thermistor curve is implemented in firmware via a lookup table. Temperatures below -10 fall out of the table and the firmware incorrectly interprets this as being a hot temperature.
The only fix is to replace the control.
Posted on Jan 07, 2009
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
Rear window washers work in all temperatures. Front washers work only when outside temps are above 0 ! Once temps are below zero there is nothing!!!
Sounds like you got it. Water is freezing up the wiper motor or wiper transmission at a certain temp due to water leakage in what is supposed to be a sealed area. (inside wiper motor, wiper trans linkage). "SOUNDS LIKE" water may have seeped in the moer seal & froze it or stripped the gears of the wipers? Good Luck Frank M
Feb 15, 2016 | 2014 Hyundai Santa Fe
Heater will not activate until outside temp. is above 40 degrees
If you have a heat pump the compressor is locked out below that temp. If you have a dual fuel - hp/gas, the gas burners should come on as would the electric heaters if you have electric heat as backup.
Jan 19, 2016 | Heating & Cooling
On a Friedrich in wall AC/Heater in the heat mode in the digital display while the unit is working fine I get a flashing 08 alternating with the temp of 74. Model # PDE15K5SB-A is this a trouble code
This is an error code for "Unit cycles more than 9 times per hour". The service manual says the possible causes are "Unit oversized" and "Low load conditions".
Jan 10, 2015 | Friedrich Heating & Cooling
Rth111 does not turn on when cold
too cold for batteries or they are low. Litium Ion work well in the cold but check tstat instructions for compatibility.
Jun 12, 2017 | Honeywell Programmable Thermostat Heater
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
It is hellishly hot outside these days, something close to 40. I bought a 6000 Haier at Best Buy and wanted it to lower room temperature to 25 Celsius. Vain hope: working non-stop day and night at high...
This window unit cant keep up in temps above 100 degrees farenheit its not going to happen. 28 degrees celcius is all your going to get in that heat Im in St. louis MO and its the same way
116 degrees farenheit heat index
Jul 21, 2011 | Haier HWR08XC7 Air Conditioner
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
Whenever the temperature drops below approx 40 degrees the door only opens anywhere from 12" to 3ft. The door works fine when the outside temp is above 40. When I unhook the door from the opener it moves...
Make sure there is no grease in the rails. This can congeal and cause this problem. The 'up force' control is on the panel where all those white wires go. You can try increasing this also.
Feb 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Jan 06, 2009 | Hoover HCA351K Bottom Freezer Refrigerator
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
100 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
