Question about Bogen Communication BOGEN PCM-TIM PHONE INTERFACE MODULE
Static on bogen pa
Speakers on system emit a low static and a clicking noise every 1.1 seconds approximately.
I bought a ddu250 and an xlr connector for it. I looked at the picture of the wiring diagram and it has the White wire going to pin 2, the black wire going to pin e and the shielded wire going to pin 1. ...
does this mic have a switch? Is this mic dual impedance? If it is dual impedance depending on the impedance of the input will determin if you use 2 or3 wires. If it is only low impedance then white to pin2 black to pin 3 and the shield to pin1. If it is low imlpedance and has a switch the red and blue wire may be connected at the switch and may also have to be conneceted to pin2 and3. any more questions call me a the store.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
servicedepartmentprolinemusic@comcast.net
www.prolinemusic.com
Jul 14, 2011 | Bogen Communication BOGEN DDU250 DYNAMIC...
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
I have a Bogen Enhancer system and have really enjoyed using it. But occasionally I get quite a bit of static (interference?) when I am teaching. Any suggestions?
I am struggling with similar issues. Adjusting the level down on your audio amplifier may help; this may raise another issue in that teacher's voice could seem too quite. Another concern with static may be the placement of the IR sensors. Haven't had much luck finding published guidance from Bogen. Nice system - just not working as well as hoped for.
Nov 10, 2010 | Bogen Communication ESYS1 ENHANCER SYSTEM...
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
The noise is certainly not coming from the speaker as I have muted it. The noise more like a low frequency noise, I am not able to decide whether it is from the fan or from some other components
Hi. Check for outside sources that might be causing the static noise. The laptop might be near an Electro-magnetic emitting device like a high-powered lamp or speakers or wireless phones or even a device with a running motor.
^_^
May 05, 2010 | Dell Latitude E4300 Notebook
I get a loud static noise, when I first turn on the yamaha ysp-1. Lasts a few seconds. Have unplugged all inputs. Problem persists.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
Mar 12, 2010 | Yamaha Digital Sound Projector Home...
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Laptop noise interference
This appears to be a problem with the soundcard or device. The mic/headphone/speakers are all usually associated with the sound card. you may have had a virus attack or problems with the items drivers. Check the device has no problems:- My Computer/Control Panel/System/Device Manager ( Yellow Exclamation ) denotes Problem. Alternatively, is to disable the Mic Input Via the sound cards control Panel.
Thankyou for using Fixya.
Mike @ compurepair.
Nov 25, 2008 | Computers & Internet
Bogen Communication BOGEN PCM-TIM PHONE INTERFACE MODULE Logo
Top Bogen Communication Computers & Internet Experts
David Payne
David Payne
Are you a Bogen Communication Computer and Internet Expert? Answer questions, earn points and help others
