Question about LG WD-3243RHD Front Load Washer / Dryer
Dlg7188wm lg dryer was converted from natural gas to propane. It worked/works properly, however I just noticed that the heat screen on the back wall appears to be burnt! What could this be caused from? How do I fix it, and what other issues would this cause? I haven't turned it on since I noticed the burnt screen because I do not want to start a fire. Please advise.
  • 163 Answers
Hi!!1 You can't do nothing about it in propane the back screen does this its normal..Sorryy...propane burns rich and smells and turns thing black..
Posted on Jan 04, 2009
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
I have a lg dryer DLG5988S is it natural gas or lp?
most of these dryers are factory set for natural gas and need to be converted to propane if using propane
Feb 09, 2011 | Dryers
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Convert propane hook up for dryer back to gas
the oriface size for propane and natural gas is the same it only has to be changed if you will be useing butane it should hook up and work the same but the propane will have a stronger sulfer smell than natural gas always connsult you gas provider if you are concerned they usualy will send tech to inspect if youhave questions for your safety
Nov 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore gas dryer works but no heat, model# 110.20702990.
make sure the exhaust vent is not plugged. shut gas off, disconnect hose, start dryer. stop and reconnect hose turn gas back on and try again.
also a propane dryer can work on on natural gas but it is very dangerous to run a natural gas dryer on propane because the orfice is too big.
Sep 23, 2009 | Dryers
Have a LG gas dryer dlg7188wm....doesn't heat
Take top off, then start unit. You can see orange glow in about 10 seconds on front bottom right by looking down from the top if the glow igniter is working.
Jul 27, 2017 | LG Dryers
Converting propane to natural gas
hi there..be advised do not attempt this conversion yourself....legislation requires you have this work carried out by a corgi registered gas engineer who will issue you a certificate for you home insurance......NO CERTIFICATE NO INSURANCE..&..YOU ARE PUTTING YOUR LIFE AND OTHERS AT RISK ..
Sir Galahad
Aug 24, 2009 | Dryers
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Conversion back to natural gas
4948EL4001B back to natural part number LG will only sell it qualified techs..but here's a start.
Jul 09, 2008 | LG DLG3788W Gas Dryer
LG WD-3243RHD Front Load Washer / Dryer Logo
146 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
