Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture warped..Can't fix convergence because crosshairs are also warped!!
My Philips Rear Projection tv has some convergence/warping issues. There is a large green curve in the bottom rear of screen about 4 inches tall, and stretching over more than half of the horizontal distance acroos the bottom. The picture has a "double vision" effect all around this area, as well as doubling along the top part as the screen as well. I tried to fix the convergence by manually adjusting the red/blue/green, but it doesn't work--The crosshairs are not straight at all, but rather skewed, and at angles so that the colored crosshairs can never disappear...The center crosshairs are relatively straight, its just the outer perimeter ones that are out of wack..the corners are the worst. Can this be fixed by me, or will I have to pay a repairman $$$ to fix this? I am pretty good with electronics/computers, so I would definately try and fix it first..this tv is a few years old- almost outdated-not really worth a hefty repair bill.. Help...thanks in advance
  • 1 more comment
  • HD 825 Nov 21, 2007
    hope to find loss cost effective way to fix the same issue I have with my 60 HD Philips TV
  • wanyej2003 Apr 22, 2008
    I also have the same problem with my tv! I fix the convergence, but the tv is still warped. With the tv being warped, are there any other specific solutions to fix the t.v. My local technician said the Phillips parts are $$$$$ and they are hard to repair!
  • jameydog Apr 24, 2008
    no manual, for this but i did try to align the convergence but to no avail. cross hairs, bent unable to straightgen. looking to take the back off and y see if there is a screw or ajuster toggle to help. is there anything i can other than call a repair man?
    Regards, James Nichols
    Nichol_n@bellsouth.net
I have a solution, same thing happened to me, have the tv in shop still. my guy said he has replaced the ssb (?cuircut board) three times. all three times the tv worked great for a day or two then the same thing would happen again. finally he figured out it was some small part, sorry cant remember what it is call. He contacted philips for support or to order the part and was informed they had to discontinue making the part because it was defective and would mess up the ssb everytime. However, even though philips was aware the part was defective and would tear up the ssb they claim no responsiblilty and no replacement part is available. If anyone knows what can be done to repair this issue or has had this problem themselves please post.
Posted on Jul 02, 2007
    Problem Solver:
  • 5 Answers
Cost to fix by a technician would be about $250 to replace the Integrated Circuit. Worth it if you ask me. Some say you can do it yourself with a soldering gun. Check other website forums such as HDTVoice.com on replacing.
Posted on Jun 29, 2007
The color on my rear projection TV is a little off. I tried to fix it by pressing the 'test' button below the screen. I can move the red crosshair perfectly on top of the set green one, but the blue...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Mitsubishi WS-65711 65" Rear Projection...
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A--- $38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
May 07, 2009 | Samsung HCM4215W 42" Rear Projection...
My philips 60" philips tv model 60pp9352 picture is squeezed at the middle (like an hour glass on its side), how can I fix?
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Mar 16, 2009 | Philips 60PP9352 60" Rear Projection...
Convergence contols on Philips 60PP920217F
You have bad convergence amps and most likley 2 bad resistors in the convergence circut.
Jan 10, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 51PP9303H17 Convergence Issue
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Oct 27, 2008 | Philips 51PW9303 51" Rear Projection...
try these sites:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
different tv same problem, same solution
Dec 05, 2007 | Televison & Video
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
1,095 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
