Question about DigiWeigh Health & Beauty
The silvercrest bathroom scale that we just bought weighs out to 0 then gives too light a weight when I get on the scale
I bought this at Lidl
r321567499
  • 74 Answers
SOURCE: owners manual for WW 47 bathroom scale
This link allows you to request user manuals...
I hope this helps.
http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
SOURCE: resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Posted on Mar 25, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
  • 67 Answers
SOURCE: Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Posted on Jul 28, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
My silvercrest talking scale which I had bought from Liddles, gives me a different reading each time I step onto it. Could it be that the batteries need to be changed?
Batteries,it could be that simple. Check the warranty. Lidl give several years warranty on a lot of stuff, if that doesn't work.
Nov 03, 2014 | Health & Beauty
I have a silvercrest kitchenscale (2009 - z25830) always worked properly but now shows the sign out2 when I press on/tare. New batteries are in. I have 4 buttoms on it 1. temperature 2. timer 3. on/tare 4....
I have the same problem, came onto this website, but I guess our scale is broken , because I haven't got any weight on the scale when I put it on.
http://www.lidl-service.com/cps/rde/SID-EE4901A4-2520664B/lsp/hs.xsl/product.html?id=8346817&rdeLocaleAttr=nl&title=Digitale%20keukenweegschaal
Aug 13, 2013 | Hardware & Accessories
I need a manual for simply bathroom body analysing scale
Could someone tell me the battery needed for the Simply Bathroom body analysing scale - model 4528?
Thanks
Apr 16, 2012 | Health & Beauty
Where can I get a operating manual for silvercrest digital kitchen scales num: Z30170. in english
http://www.lidl-service.com/cps/rde/xchg/SID-EE4A0FEC-2E826FB3/lsp/hs.xsl/product.html?id=8346817&title=Digital+Kitchen+Scale&count=1
Aug 04, 2011 | Microwave Ovens
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
The weight jumps around. If I get off the scale and on again, the weight changes by 5 pounds. I am sure neither weight is correct.
You're only suppose to weigh yourself once a week. Make sure you're doing it after you've gone to the bathroom in the morning and with no clothes on. Other than that, I'd make sure the floor you set the scale on is level and that you are holding very still while weighing.
Feb 28, 2010 | Conair WW60 Weightwatchers Scale
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Resetting the scale
Jan 24, 2009 | Health & Beauty
Health & Beauty Logo
1,089 people viewed this question
Top DigiWeigh Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DigiWeigh Health and Beauty Expert? Answer questions, earn points and help others
