AMD SOYO Winfast dragon 760M02-GX-6LRS Driver
5 Suggested Answers
TheKLF99
  • 4 Answers
SOURCE: power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Posted on Nov 14, 2008
bad_theta
  • 31 Answers
SOURCE: vga driver
I found the site to suggested to you.
Foxconn Site
Link
Direct Driver Download
Link >>> VGA Board Driver
Link >>> AGP Driver
Just Click and follow the link
Or you can download it from sis website, coz this motherboard uses the SiS 760GX motherboard chipset drivers, which you can download directly from SiS:
http://www.sis.com/download/
Posted on Jun 03, 2009
  • 10406 Answers
SOURCE: Hi ! I've got a Winfast 760M02-GX-6ls
First, ensure that the leads from the motherboard to the internal speaker are connected.
Second, try "flipping" the connector, at one end, to make sure that you got the "positive" and "negative" leads correctly connected.
Third, put a multimeter onto the leads on the motherboard, and then turn the computer on,
and watch to see if the multimeter records any voltage where the "beep" should be.
Fourth, try replacing the AMD CPU, if only temporarily.
Posted on Aug 02, 2011
bronk50
  • 27725 Answers
SOURCE: need manual for winfast 760M02-GX-6LS motherboard
http://www.brothersoft.com/downloads/computer-manuals.html
you will have to type in the motherboard in the top search tab
http://help-site.com/c.m/
this site will tell you how to use something
http://www.manualsonline.com/
http://www.easyhelpguide.com/manual/ASRock.html
http://www.easyhelpguide.com/manual/index.html
here are many manuals and guides on how to use things
hope this helps you
Posted on Oct 29, 2011
I need drivers for windows7 32bit
you will find it on the manufacturers website
Jan 23, 2013 | Foxconn Winfast 760gxk8mc 760m02-gx-6lrs...
Can i upgrade the ram
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
hope this helps
Sep 11, 2012 | Generic 760m02-gx-6lrs - Winfast...
Winfast pc760m02-gx-glrs motherboard layout
Read the manual and it will tell you the process.
Get onlineand got to www.google.com In the google search box type: "WinfastSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
Jun 05, 2012 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
Aug 02, 2011 | Computers & Internet
Vga driver
Foxconn Site
Link
Link >>> AGP Driver
Jun 03, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Required the above motherboard driver
post the model of your motherboard ,,and i send you a link to driver
May 02, 2009 | Computers & Internet
No video driver for WINFAST 760GXK8MC
760GXK8MC  VGA Driver
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0000193
Dec 22, 2008 | Computers & Internet
Winfast 760m02
I HAVE VGA AND AUDIO DRIVER FOR MODEL NO:PC 760M02-GX-GLRS
PLEASE HELP ....................
Aug 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
