Question about Celestron CG-5 Mount Telescope
Need dimensions for CG-5 cinch-down bolt
I am building a pier mount for my CG-5, and I need the cinch-down bolt size and thread. - Don
  • Don Grodecki Jan 07, 2009
    I think you are right, 10mm. Also, I think the thread pitch is 1.5.
  • 44 Answers
Don, if you mean the handscrew that retains the mount in the hub, I believe that it's a common 10mm. Should be able to get one a big box hardware. I have seen CG-5s with the hole bored out and retreaded to 1/2NC to mount on a Meade HD Field Tripod. HTH, Geo.
Posted on Jan 07, 2009
I have a 2007 PT Cruiser 2.4 and have lost the thermostat housing bolts. What size are they >
I don't know, typically M8 x 1.,25 or 5/16" UNF or UNC though manufacturers have used many other sizes including such oddball sizes as M7 x 1mm. Recognising bolt and thread sizes is one of the mechanic's core skills.
You could try turning a few likely looking bolts in by hand or if you prefer the correct bolts should be available from the dealer as spare parts. If they aren't available the parts manual will state the bolt dimensions.
Jan 27, 2018 | Cars & Trucks
How hard to change oil pump on mercury Capri.build date 09/93
remove oil pan and then it is a cinch. but getting the oil pan off with the engine in the car is tricky. remove all the bolts to oil pan and then the bolts to the engine mounts and transmission mount and jack engine up enough to remove oil pan
May 10, 2015 | 1993 Mercury Capri
Thread size needed for a 1997 grand am rear wheel hub assembly
take out a close bolt (same area)and take it to a bolt /fastener shop. They will be able to measure the size and thread and will supply a bolt to the correct grade requirement;
Dec 25, 2013 | Pontiac Cars & Trucks
I have a Rover Quattro 40 and I need to replace the three bolts surrounding the centre bolt which attach the blade plate. Because they have sheered of I don't no what size they are. Does any one k
If I am understanding you correctly you are talking about the spindle and the hold down bolts for it. Most spindles use a 5/16 course thread 1 1/2 inches long with a 1/2 inch head size
Jan 03, 2013 | Briggs & Stratton Garden
What size is the bolt and thread size needed for the tripod mount on the Canon G12 digital camera?
Hi Winterhawk.
I think you'll find all camera tripod mount stuff is termed 1/4-20. That's 0.25 inches diameter, 20 threads per inch.
Obviously you want to make your bolt short so you don't crack the camera case, strip the bolt, or otherwise get into trouble.
See also:
http://en.wikipedia.org/wiki/Tripod_%28photography%29
Cheers and enjoy your project,
eastpole
Jul 12, 2011 | Philips Avent Scd520 Dect Baby Monitor
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
Center main mototr mount bolt is missing,need size of bolt so I can replace it myself.
More than likely the mount is bad and you will have to buy the bolt from the dealer or a fabricating shop that sells metric bolts, or go to a junk yard to get a replacement for same car. pull the nut off the other side and measure from the top of the bolt to the end of the threads then go buy one at the store using the nut as your size guide and thread pitch and get a grade 8 bolt to replace it with.
May 31, 2009 | 1993 Toyota Camry V6
CGE mount sizes. (not inc. tripod)
Nice mount! --- I would suggest calling OPT as they sell these and should be able to help you--
Here is their web site--
http://www.optcorp.com/
Clear Skies!
Dec 10, 2008 | Celestron CGE German Equatorial...
Wall Mount
I found that the screw holes in the back that should have thread from the top down are threaded only near the bottom of the hole. You will need to purchase longer bolts/screws to attach the mount. Also, if it has the built in DVD player you will need to purchase a few plastic washers to build the mount up over the DVD player and to make the other side even. It is POSSIBLE to mount this TV it is just a large amount of work! I hope this can help!
Jan 10, 2008 | Televison & Video
Celestron CG-5 Mount Telescope Logo
358 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
