Question about Hotpoint WMA50 Front Load Washer
Will not run wash properly
What works:
Rinse ie. fills with water
Drain ie. empties to drain
Rotation ie. spins easily
What doesn't work:
Spin - high speed spin fails
Wash - seems to run a type of programme but does not fill with water and wash clothes.
Is there a sensor that is not detecting
  • Hotpoint Master
  • 3,463 Answers
The sensor you are referring to could posslbly be the water level switch which controlls the level of water,and also. is a factor as to wether the washer will spin or not, it also is part of the heater circuit, so it has numerous functions.
I t can be found at the top right front of the washer, and is about 3" in diameter, and has a thin plastic tube going to it.
it could be sticking, there is no sure fire way of testing it properly, but you could try tapping it and blowing down the tube, it may solve the prob.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Jan 04, 2009
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
I have an ecosmart Fisher&Paykel. Goes OK through all the cycles until the spin. Won't empty water. Tried rebalancing load, and it is level. Manual says it could be a suds build-up and to do a deep...
Hi there, it sounds like your drain pump is not working. Tip the washing machine back and look underneath. The drain pump has a little black fan on it. Disconnect the hose to see if there's anything stuck in the drain, like coins, hair clips etc. Clear out the pump and remember to reconnect the hose securely before trying out the washing machine.
Please remember to rate this solution, thanks.
Jul 01, 2011 | Fisher and Paykel Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint WMA50 Front Load Washer Logo
192 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
