Question about Audiovox PPC 4100 Pocket PC
The phone does not turn on
|turn off my phone and when i tried to turn on, this doesn't work. The battery is ok. The hard reset doesn't recovery the phone function. Please, is urgent.
0 characters
1 Points
My htc hd2 wont go past the tmobile start up icon
Try doing a battery pull. If that doesn't fix it, you will need to try a hard reset on your phone. If that doesn't work, you will need a replacement phone. If you have insurance on your phone, use it to get a replacement. If not, see if it's still in warranty and try to get a replacement through the manufacturer.
-ex Sprint rep
Jul 04, 2011 | HTC PDAs
Connected the phone to a wall charger but the charging light did not come on. I tried another charger (my sone has one as well) but that still did not indicate a charge. I left the phone all night in case...
first try if your charger is working.
next, try to remove your battery and check if it is not dead by using a multi-testers and place it again if it is ok.
if still not charging then most probably that you have a software problem. have your phone reformat at to your nearest service center. you you will be needing a special gadget to do this.
Jan 08, 2011 | T-Mobile MDA
Blackberry 7130e. It is showing that it has a signal but i cannot recieve or make any phone calls or texts. It has an arrow flashing at the top by the signal like its sending somthing do i...
This problem happens on pretty much any computer-related device. Something happens and you can send anything. It’s annoying, but there are actually two ways to fix it. You can perform a soft reset, which is done by pressing the ALT + CAP + DELETE keys on your handheld at the same time. If this doesn’t work, perform a hard reset. This is done by finding the RESET button at the back of the handheld. Sometimes, this button might be near the bottom, under the battery cover. Press the RESET button using a pin or paper clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
Jun 05, 2010 | RIM Blackberry 7130e Smartphone
My G1 screen goes blank when i close it
First try SOFT RESET
1) Turn Off the Phone
2) Remove Battery
3) Remove Sim Card
4) Put battery and sim card again
5) Turn On the phone
6) Press Menu
7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this).
Press "reset phone"
1) Turn off the Phone
2) Press HOME + POWER KEYS (keep them holding for about 25 secs)
until you see a screen with a phone and a triangle.
4) press ALT + l ( TO SHOW YOU OPTIONS)
Note: When I write the sign + you don't have to press the + sign, it means that you need to press both keys @ the same time.
May 03, 2010 | HTC G1
Samsung Blackjack freezes
If you want, you can try doing a hard reset, which will erase everything that's not on external storages. Here is the hard reset procedure:
1. Removing the battery without turning it off.
2. Reinstall the battery and turn the phone on with navigator key pressed down.
3. press any key to skip to prompt.
4. press yes to reset the phone.
Good luck.
Oct 02, 2009 | Samsung Blackjack SGH-I607 Smartphone
Htc locked touch screen mal functioning
Try mDesktop for remote control from your PC to unlock the phone.
Apr 10, 2009 | HTC Touch P3450 Smartphone
I have a a380i cell phone that will turn on and off but it doesn'
Could the touch screen be damaged? Try resetting the unit.
You may have a reset button or else take out battery and restart.
Jan 08, 2009 | PDAs
Hard reset ipaq 111 running windows mobile verson 5.2
just so you know, this is a LG KU990 forum.  these phone dont run windows mobile of any version.  I think there is a backup battery built into the phone.  Also, are you saying the hard reset 3 keys did not perfrom a hard reset or that the hard reset did not do annthing?
Sep 09, 2008 | LG KU990 Viewty
HTC PPC-6800 Smartphone errors
Okay take out battery and put phone on charger .. then try a hard reset . and then go to a soft reset. after that put battery back on and soft retset and see if it works .
Jul 04, 2008 | HTC PPC-6800 Smartphone
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Audiovox PPC 4100 Pocket PC Logo
26 people viewed this question
Top Audiovox PDAs Experts
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox PDA Expert? Answer questions, earn points and help others
