I have a matrix ceramic hob MHC001 to install, i know what the wires represent but the hob is numbered as 1,2,3,4 giving no info as to what these numbers represent, the installation guide does not say
What does the wiring slots that are numbered represent, the installation manual does not say, i know what the wires are but the wiring slots are numbered but there is no indication of what the numbers represent as in live, neutral etc?
5 Suggested Answers
  • 1462 Answers
SOURCE: Hi I have fitted an
yes you must link all live terminals. links usually come with the installation kit but you can make them from suitable size wire
Posted on Jul 09, 2008
  • 12 Answers
SOURCE: Need User Guide for Hoover washing machine
you can download manual from hoover.co.uk
Posted on Mar 27, 2009
jmgldsmth
  • 1869 Answers
SOURCE: which wires are live,neutral and earth.
Black=Live
White=Neutral
Green= Earth Ground
Posted on May 08, 2009
SparkyNZ
  • 43 Answers
SOURCE: wiring problem
If they only way to fit your cable is by using the terminal push on connector (which, frankly, i'm not 100% sure what that's describing) and you can easily get that from your hardware store then yes, as long as you can connect up your wires without difficult and without stray copper.
Red wire is live, but white may be live as well during one aspect of operation. Usually neutral is black or blue. If your cable has red white and blue color in it then your using a 3 phase cable. A single phase 3 core cable will have red/brown black/blue green/greenyellow.
Hope this helps. Let me know.
John
Posted on May 09, 2009
GIBSON LES PAUL CUSTOM SER# 7-1755 I HAVE NEVER SEEN A GIBSON# LIKE THIS CAN YOU GIVE ME SOME INFO LIKE DATE MADE & ANY FURTHER INFO
Ser # 7-1755.
The "7" represents the year 1957.
The numbers 1755, "1" represents this model is potientially a reissue made in 1961,
The "755" represents the instrument number made that year.
Apr 17, 2017 | Gibson Music
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Feb 05, 2010 | Cooktops
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Dec 05, 2008 | Cooktops
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
110 people viewed this question
jasbo
jasbo
