Question about HP DeskJet F380 All-In-One Printer
I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
When I try to print I get the following error message:
"Incorrect Print Cartridge(s)
The following print cartridge is not intended for use in this printer
Black
Refer to printer documentation"
The Black Ink Cartridge I'm using is specifically made by HP for this printer (No. 21)
I tried re-inserting the cartridge, cleaning it, re-starting the computer but nothing works. Hope you can help. Thanks.
  • lessmaader Jan 15, 2009
    all lights flashes
    all lights flashes when i swich my printeron
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
Take it back, might be the wrong one, or manufacturer's defect?
Mar 14, 2010 | HP Office Equipment & Supplies
Error occur after cleaning printer
Make sure the cartridges are properly returned to their carriage. Try to take them out and then turn off the printer. After a minute, turn them on again. If the printer ask for a print cartridge, then open the cover and put back the cartridges again.
Dec 13, 2009 | HP DeskJet F380 All-In-One Printer
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
HP F380 Error message
your alignment is not detected properly
first check your print cartrages are ok or not if it is ok the align print cartage and put it in the scanner and once scan it
Jul 18, 2008 | HP DeskJet F380 All-In-One Printer
Printer refuses to print Error Message
i suggest you inspect the bottom, to see if anything is compromising the connection pad.
Feb 27, 2008 | HP DeskJet 950c InkJet Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
691 people viewed this question
Ben Johnson
