Hi I have an lg f1443kd washing machine which sounds like there is a coin in the drum would it eventually come through the filter? Can I fix this or would I need an engineer?
2 Suggested Answers
  • 1462 Answers
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
How to find drain filter to clean out machine making funny sounds
follow the steps below to get to the bottom of the problem.
1 Turn off your machine Before doing any sort of maintenance on your washing machine, you should turn it off and fully unplug it. If your machine is mid cycle when it starts to play up, follow advice in your washing machine's instruction manual for stopping and draining it.
2 Check the rubber door seal and drum Items that get into the drum can cause both strange sounds and a number of problems. most common culprits are coins and bra wire. Mostly coins remain in the drum or caught in the rubber seal - so these are the first places to check.
3 Check the lint filter Some items loose in the machine can work their way down to the lint filter.
hope this helps but if not follow the video on the link below.
http://www.which.co.uk/reviews/washing-machines/article/how-to-deal-with-strange-sounds-from-your-washing-machine
Apr 16, 2016 | Hotpoint Washing Machines
Clinking sound in a Siemens WFXD5200UC/01 front loading washer
I would suggest that a small thin metal item has got into the outer drum unit. This is the space between the internal spinning drum and the outer casing. This can sometimes happen by the object passing between the rubber door seal and the drum. Not easy to get out, however if it is small enough it may eventually find its way into the pump filter trap. There is a small round cover plate at the bottom right hand side of the machine. Behind the cover is the filter trap, open it up (when machine empty) and check for the object every so often. To open the filter turn the plug cover about a third anticlockwise and it should release. Pull gentle on the plug to remove from the machine.
Feb 14, 2016 | Siemens WFXD5200UC Front Load Washer
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
Where is the filter on my wf740 hotpoint
Maybe something jambed in pump, lint , coin or similar. Just fixed my LG machine coin in pump..Unsure of layout on Hotpoint but simply follow drain hose to pump.
Apr 17, 2013 | Washing Machines
Sounds like coins between the basket and drum. How do I remove the coins?
If it has baffles for washing, check to see if you can lightly press the baffle to one side (press firm but don't snap it out) while rotating the drum by hand. I do this with my Whirlpool Duet and the coins eventually just slide out and into the drum where I can see them.
Dec 06, 2010 | Maytag MAH8700A Front Load Washer
My LG F1443KD washing machine keeps saying load out of balance even when it is empty on a calc cycle. Help!
See here for a solution http://www.amazon.co.uk/product-reviews/B00364KPZ2
Dec 04, 2010 | Washing Machines
User manual needed
Hi there at great risk of sounding a cad..(.was this cash or a cheque)...id doubt very much if its anywhere under the drum....if it WAS in the pocket it would still be there crushed and a little discoloured..had got into the drum it would have blocked the filter .IF he was paid in coins then youd have stopped tthe machine..
regards Sir Galahad
Aug 20, 2009 | LG WFT1071TP Top Load Washer
LG front load washer A coin fell in between drum and housing.coin rubs on drum while spinning. how do you access the area between the drum and housing?
take off the front panel
on the bottom/front of the drum is the heater- held in with 10 mm nut - slacken the nut- this will loosen the heater in its holder- pull out the heater- this gives you access to the bottom of the tank
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Nov 19, 2008 | Zanussi ZWF1430W Front Load Washer
I cant get the filter out of my washing machine help please
you probably have something like a bra wire jammed in there. no option but to pull real hard with a pair of pliers.
smell is not caused by filter. often smell is due to using liquid detergent. after you have done filter, put on the hottest wash and change to powder detergent
Jul 17, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
