Question about Frigidaire GLEB27S7A Electric Single Oven
Can a fridgidaire wall oven model gleb2757a be installed under counter with a jennaire cooktop above. I'm in a wheelchair and need the oven under counter
    President:
  • Frigidaire Master
  • 2,651 Answers
Heres a pdf of hte installation guide, pg 8 indicates you can and gives the dimensions/specs
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318201508.pdf
Posted on Mar 01, 2009
I just had a Frigidaire electric Single Wall Oven (FGEW2745) installed under a Bosch gas cooktop. The cabinet maker didn't allow enough room for the oven so my contractor had to lower it. However, as...
Any handle you replace on the oven will certainly void its warranty, especially if you have to drill the door to fit it. Generally the oven handle is designed for the oven, and as such most manufacturers dont make different door handles for them. Most likely you will need to get a different oven altogether, or void your warranty and find a suitable handle and attach it to the oven door yourself by some means.
Hope that helps.
Feb 24, 2011 | Frigidaire FGEW2745KB FGEW2745KW Electric...
Jennair 30" wall oven display is totally off.
Part # 71003424 runs around $185.00
It's a common issue in Jen-air ovens,the display burns out,the control itself will still work fine but you just can't read it.
Sep 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Jan 13, 2018 | Frigidaire 30 in. Electric Gallery Series...
How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
JennAir W30400P
i think you can get downloads from maytag.
Mar 25, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Oven door won't unlock
kittyboy The first step I would recommend you to do is to turn the circuit breaker on, then set up the oven clock. Start the self clean for any amount of time, wait about 30 seconds and push the cancel button. Most of the time it helps to eliminate the problem. If it would not help, let me know and we will go further. In that case I will need the complete model number. If it is the free standing range, you can find it on the frame behind the bottom drawer. Gendos...post back
Feb 26, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire GLEB27S7A Electric Single Oven Logo
114 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
