Question about Microsoft Wireless Receiver For Xbox 360
I already tried it.
I already tried pressing the button on the console and the one on the controller but it wont connect.
    Problem Solver:
  • 13 Answers
Get someone to press the botton the same time as you but make sure the 4 rings are flashing or doing the same as on your controller, if that does not work then hold your button down and tell them to just press it
Posted on Aug 09, 2009
Why wont my ps3 controller connect to my ps3 console
Most often this is because the controller is already assigned to another system or lacks the charge to send/recieve a signal. The simplest way to solve this is to connect it to your PS3 via the USB charger cable, then try pressing the Home button again. If the problem persists, there is another fix; On the back of the controller next to the screw that holds it together is a very small hole. Try inserting a pin into the hole and hold it there for a few seconds, then try the above method again. This is a hard reset for the controller settings and has solved what few problems I've had with it connecting.
Hope this helps!
Oct 29, 2012 | Sony Playstation 3 (PS3) Console
My controller wont connect
Try connecting the controller to the console using the USB cable then press the PS button to sync the controller to the console.
Hope that helps.
Mar 13, 2011 | Sony Playstation 3 (PS3) Console
Controllers will not connect to playstation console.
connect controller to ps3 using the chragin wire then lick the ps button on the controler
if nothing happens turn on ps3 manually with the controller still connected and it should recognise it again
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 28, 2009 | Microsoft Xbox 360 Wireless Controller
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Aug 15, 2009 | Microsoft Xbox 360 Console
When trying to link wireless guitar to x-box 360 all four green connection lights come on the guitar
press the connection finder button the little black button on the **** of the guitar then press the little white button on the front of your x box if you already knew that i appologize but i tried anyway.
Jul 30, 2009 | Microsoft Xbox 360 Controller
My controller will not connect on my ps3.
Sounds like the controller knows it belongs to the other PS3. It has already "paired" with one console, so that's why you're having a hard time trying to get it to pair with console #2, comprende?
Make sure console #1 is a "hard off", like switched in the back. Now flip your controller over & put a pencil or pen tip in the reset hole. ( Just to the right of the center screw hole.) NOW connect said controller with the USB to console #2. Hold the PS button for two seconds. All 4 lights will flash 5 times, then the 1 light should stay on, Boo-ya! You're PAIRED!
May 30, 2009 | Sony PlayStation 3 40GB System
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
Mar 01, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless controller flashing green light but wont detect xbox360?
Have you tried resyncing your xbox and controllers? On the controller, press the little circle button on the top of the controller, between the bumpers. On the 360, there's a small circle button, about half inch wide, next to the memory card ports. Press that as well.
Jan 05, 2009 | Microsoft Xbox 360 Console
Microsoft Wireless Receiver For Xbox 360 Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
