Question about Toshiba Computers & Internet
Bright spot on my laptop screen
I woke up this morning and there is a spot on the bottom left side of my screen that is brighter than the rest of the screen.
mailtoravi
  • 186 Answers
SOURCE: white bright spots on screen
These kind of patches or spots are called as Dead Pixels.
If you find any thing that doesnot change colour along with the other part of the Display according to the image, those spots are referred as Dead Pixels where the LCD needs to be replaced.
Contact your nearest HP Authorized Service Center and find the cost to get the LCD replaced.
Posted on Sep 15, 2008
cpenzes
  • 1102 Answers
SOURCE: i can't increse the brightness on my gateway laptop
You may need to just update your driver.
If thats not it then in control panel you should have a graphic settings somewhere.
Or if you look at your laptop keys hit the fn button and then look for a button at the top.
Thats where my laptop brightness and contrast is.You may have to try a few different keys but don't worry if you press the wrong key you can reverse it by pressing function ( fn ) and same key again.
Posted on Jan 12, 2009
Chillimar
  • 117 Answers
SOURCE: used Compaq Laptop screen not bright
Usually most laptops has blue/white function keys top on keyboard they can be used together with Fn button that is left bottom side of keyboard. For example on my laptop with F4 and F5 together with Fn can adjust brightness.
Best wishes,
Chillimar
Posted on Jan 27, 2009
  • 336 Answers
SOURCE: Operation system not found
First please try to boot to last known good configuration ..
To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. .
If you will still see the same problem, then please boot to safe mode..
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
From safe mode you can restore your PC to the latest restore point when your laptop is working fine.
Regards,
Jeep Brainy
Posted on Jul 26, 2009
Geekman
  • 32281 Answers
SOURCE: dull laptop screen back light
You may have a faulty CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Posted on Dec 30, 2009
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
I can't find how to adjust the brightness of my screen in Window Xp on an MSI laptop
Press and Hold the FN function key located near the bottom left on the keyboard then hit the key that adjusts the brightness.It will be one key for brighter and one key for darker. Look for the keys they will have the icon of a round sun or washer looking circle with the up or down arrow on it.
Apr 27, 2012 | MSI MegaBook Computers & Internet
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
SAMSUNG NETBOOK SCREEN NEEDS TO BE BRIGHTER
to adjust the brightness click start menu then go to control panel. From the control panel look for POWER OPTION. At the left side you will see "ADJUST THE DISPLAY BRIGHTNESS" option
Sep 10, 2011 | Samsung N120-12GBK Netbook
How do I darken my screen ..it is to bright - acer -aspire 5100. Where is the Fn key located on the keyboard?
Hi
Fn key at the bottom left between the Ctrl and Winkey
To adjust the brightness, hold the Fn key and press the cursor key - down darker, brighter up
Sep 20, 2010 | Acer Aspire 5100 Notebook
Toshiba M35 S359 Laptop screen brightness
you can try windows up date, or check the control panel, locate display and check the Brightness settings.
It is also possible that part of your screen bulb is dead, that's why one part is dimmer.
But there is no drivers that will make your screen bright.
Take care.
May 28, 2010 | Toshiba Satellite M35-S359 Notebook
Used Compaq Laptop screen not bright
Best wishes,
Chillimar
Jan 27, 2009 | Compaq Presario Notebook
Bright spot on screen.
I'd say that's just the way they're made. The background light for the screen just doesn't illuminate evenly. If it's noticeable enough I'd try to get it replaced under warranty. This can also happen when the screen is pushed and it gets damaged, but if it's happened twice it's probably just the way they're manufactured.
Nov 09, 2007 | LG 32LC7D Television
Computers & Internet Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
