Question about Bissell 1693 PowerSteamer Upright Vacuum
The bissell power steamer will not suck back up dirty water
SOURCE: my carpet cleaner
I took my Bissell proheat apart trying to fix the suction in it. I finally realized that the red filter has to not only be cleaned but also opened to get the suction needed for a good cleaning.
Posted on Apr 23, 2008
  • 25 Answers
SOURCE: bissell 2x wont **** up the dirty water
My machine would not **** up the dirty water either. I tried everything, read the "troubleshotting" section in the manual and nothing worked. Then I discovered there is a little FILTER that is not mentioned anywhere and is hard to see. It was clogged with dog hair. It is in one of the two removable sections on the top of the machine. It is NOT in the bladder section but the section with the dial to switch from floor to tool. It is red and about 1 inch long. There is a little door on it that you flip open (it actually looks like you can remove it). Flip the little door open and you will probably find a bunch of gunk. Remove it and the machine should work perfectly. Mine now does! Good luck.
Posted on Sep 12, 2009
  • 14 Answers
SOURCE: water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Posted on Jun 07, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell Power Steamer Proheat Plus not dispensing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfsghs
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: not sucking up water off carpet
heatman101
fgqwe
Why want my quick steamer suck up dirty water?
Check the manual for filters. They are generally small and need to be cleaned after each use. Consumer Care at 1-800-237-7691
Jul 19, 2014 | Bissell 1970-R Carpet Cleaners
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Will not **** the dirty water back in.
check for clogs in hoses and head.mine gets clogged up all the time.
Jun 06, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell carpet steamer not working
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Doesn't return the dirty water to the tank, after apply the water
My Bissel has been having problems sucking the dirty water back into the tank. It's like it works for half a dozen uses and then just stops working. After I turn it on and off for a couple of hours trying to troubleshoot the issues it just starts working out of the blue again and sucks up the dirty water. I know there is a yellow stopper that goes up and can stop the flow but that's down and not the issue here.
Sep 21, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissel Power Steamer Pro
yes you can but it would require taking the entire hood of to replace it ( it hooks on inside there ) but those machines need to be opened very carefully and you need to make sure several pieces are back a certain way, so i would take it to an authorized bissell repair center, go to there website and put in your zip code to find the closest one to you.
Sep 24, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1693 PowerSteamer Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
