Question about Optics
Position of lenses inside Seikanon 20x-60x 60mm spotter scope
I took it apart to clean it and am not entirely certain of the positions of the lenses.
  • 37 Answers
SOURCE: Positioning of two lenses at the front of Edu-science telescope
You might find this info helpful http://www.spacealberta.com/equipment/refractor/collimate.htm
good luck
Posted on Aug 01, 2009
SOURCE: lens needs putting back together
could you please let me no haw to work the ray cop we have no instrutions thankyou sonia holt
Posted on Sep 03, 2009
SOURCE: my 9t eye piece was rattling and mislined. I took
Never disassemble an eyepiece unless you know exactly how to put it back together. Only the outer glass lens ever needs cleaning.
Without knowing exactly what link of eyepiece you have (they are all different designs) it's impossible to tell you which way the internal lenses go.
Your best bet may be to simply purchase another eyepiece.
http://www.agenaastro.com/Telescope-Eyepiece-s/3.htm
Posted on Nov 07, 2009
SOURCE: Someone took it apart to clean it and i don't
This is a small 60mm refractor telescope. The main lens probably screws on the from of the telescope.
You will also have a small finder scope that mounts on top of the main tube.
Several eyepieces
and a diagonal.
You may also have a 2x barlow.
Put the diagonal into the back of the telescope, then put the eyepiece into the diagonal. That's it.
Now practice focusing on a distant object during the day time. Read my tips on my profile page, and read this:
http://www.texasastro.org/telescope.php
Posted on Jun 23, 2010
SOURCE: How do you properly clean
ONLY the outside surfaces should ever be cleaned. Follow these directions:
http://www.televue.com/engine/TV3_page.asp?id=103
Posted on Jan 01, 2011
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 | The Optics
What is a digiscoping?
Digiscoping is the practice of shooting digital photos through a Spotting Scope.The telescope magnifies the subject image for the camera, just as it magnifies the subject image during visual use.
The magnification is usually in the range of 20x to 60x for spotting scopes typically used by birders.
Mar 15, 2018 | Optics
What would be the best spotting scope Under $200?
Celestron Ultima 80 Spotting Scope
This economical device is genuinely popular on the market. It is a large aperture spotting scope affordable for everyone. It needs more cost for a conventional 60mm scope. It is helpful in poor lighting conditions. They are great for long-distance viewing. You can use it in twilight or under heavily overcast skies.
The zooming lens of this scope is capable of zooming from a mere 20X up to a massive 60X magnification. You can easily handle it. The zooming knob is very smooth. It has large 80mm objective lens. It gives you over 77% more light grasp than a conventional 60mm scope. It has built-in 80mm objective lens are outstanding for light gathering.
It is a refactor-type scope. The achromatic objective lens used in this scope. The product comes built with quality materials. It has outstanding light transmission capabilities. Enhancement of brightness becomes easy. It also increases the clarity of the spotting. This scope is a well-built device. It can be used efficiently in rugged conditions. The device's rugged nature makes it a perfect thing in all circumstances. It is waterproof too.
Mar 07, 2018 | The Optics
I have a Leica Televid 77 with a 20x - 60x zoom ocular. The scope fell over and now the zooming knob is difficult to turn. The zoom does still work, it is just much harder to turn than before. The...
Yes you bent the shaft on the knob or the gears inside the focuser. Order another complete focuser from Leica.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 01, 2011 | Leica Televid 77 (60 x 77mm) Telescope
How do I properly arrange the objective lenses in the Meade 285?
The OBJECTIVE lens is the one in the front of the scope-- you DID NOT take it apart did you?
You only needed to clean `the outside of the glass elements. Read my tips on my profile page about why you never disassemble these and or eyepieces completely.
Mar 24, 2011 | Meade Polaris 285 (225 x 60mm) Telescope
Someone took it apart to clean it and i don't think they put the parts back in the right places. i need a blow apart of the scope to put it back together right. Can you help?
Several eyepieces
and a diagonal.
Jun 23, 2010 | C-Star Optics 60700 (60x700) Telescope
Need 80mm eyecepie,for swift spotting scope #821.
LARGEST EYEPIECE MAGNIFICATION LENS FOR THE SWIFT 821 IS 60MM. THEY DO NOT MAKE AN 80MM FOR THIS MODEL. THE EYEPIECES ARE INTERCHANGABLE IN 15X, 20X, 30X, 40X, AND LASTLY 60X.
Sep 07, 2009 | Swift Optics
Lens needs putting back together
Sep 03, 2009 | Kowa Optics
Image upside down
Hi, this is a common "problem" for astronomical telescopes. Same with my Meade 3" refractor and spotter. It is actually a design 'feature' not broken.
The issue is that most astronomical telescopes naturally show images upside down, or some combination of upside down and left-right.
(Astronomers usually don't care, because space has no up or down.)
It is just the way optics work when lenses or mirrors bounce and bend light. (And since the professional astronomer wants the most light and most direct image, they usually don't want extra devices just to make it right-side up.)
Reason that binoculars don't do that , is they employ special internal prisms to get the image back right-side up.
Easiest solution for astronomical telescope is to buy what is called a "star-diagonal" or "image-erector prism". These will usually make the image look normal for us earth-based folks.
I do not know what exact type your Meade 227 telescope is, but the spotter scope is most likely a simple refractor. So it MAY be possible to install a star diagonal onto it. Or might not. Depends on the exact spotter scope design.
Another option may be able to buy a replacement spotter scope that is designed for correcting image orientation.
Aug 10, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
My wife got a BUSHNELL 78-9512, inside lense fell out
Here is a manual for a typical refractor style telescope---
http://www.bushnell.com/customer_service/manuals/telescopes/78-9512_Deep%20Space.pdf
Jan 01, 2009 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Optics Logo
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
