Question about Savin Office Equipment & Supplies
I have a Savin 3515 printer, scanner and fax machine. The problem I am having is I can print from my computer but can not scan to my computer?
Beni S-P
  • 1006 Answers
SOURCE: Help with HP d135 all in one printer,scanner, fax
HP Error Codes
These error codes apply to many HP & Panafax machines
001 recording paper jam
002 recording paper jam
010 no recording paper
014 print cartridge is not attached
015 out of ink
017 wrong paper size
030 document misfeed
031 document jammed or exceeds maximum length (2 meters)
039 during dialing, STOP was pressed
041 out of toner
045 no toner cartridge
060 a cover or door is open
061 a cover or door is open
063 jam access cover is open
316 clean the ink station overflow tray and encoder strip on inkjet models
400 during initial handshake, RX station did not respond; comm error
403 no polling capability at remote side
404 during initial handshake a comm error occurred
405 during initial handshake a comm error occurred
406 password mismatch
407 no confirmation from the RX station for the previous page sent
408 remote side confirmation of previous page is illegible
409 remote side confirmation of previous page is illegible
411 polling password does not match
412 no data from the transmitting side
414 polling password does not match
415 polling transmission error
416 received data has too many errors
417 received data has too many errors
418 received data has too many errors
419 received data has too many errors
420 machine enters RX mode but receives no command from TX side (not a fax calling)
422 interface is not compatible
427 interface is not compatible
430 comm error occurred while receiving
434 comm error occurred while receiving
436 received data has too many errors
456 memory overflow on confidential document or relay request
490 received data has too many errors
492 comm error occurred while receiving
493 comm error occurred while receiving
494 comm error occurred while receiving
495 telephone line disconnected
540 comm error occurred while transmitting
541 comm error occurred while transmitting
542 comm error occurred while transmitting
543 comm error occurred while transmitting
544 comm error occurred while transmitting
550 telephone line disconnected
552 comm error occurred while receiving
553 comm error occurred while receiving
554 comm error occurred while receiving
555 comm error occurred while receiving
580 sub-address TX to a unit without sub-address function
581 sub-address TX to a unit without sub-address function
601 ADF misfeed
623 no document was on the ADF
630 redial unsuccessful (busy line or no response)
634 redial unsuccessful (busy line or no response)
631 during dailing, STOP was pressed
638 power failure occurred during the communication
640 telephone off hook after comm is completed
870 memory overflow while storing TX documents
879 memory overflow while storing RX documents
975 DRAM parity error (document info in memory is lost, very common, also clean encoder strip)
HP 200/300 and similar models GPM (printer assembly) failure: When the inkjet carriage is homed on the right side of the unit, the spring pointing toward the rear of the unit passes under 2 "actuators" that appear to be identical (mounted vertically, L-shaped). Under heavy usage, the lower end of these actuators is worn away. To remove the actuators for inspection, carefully rotate the paper pickup feed wheels while pulling upward on the L-shaped actuator (compare the 2 actuators, or compare them with actuators from a comparable machine that is in working order).
Many HP and Panasonic inkjet models are comparable and parts can be ordered from Matsushita.
If there is an encoder strip (scale) in inkjet models, clean it to correct a wide variety of problems (HP 900, OfficeJet, Panafax UF321). The encoder strip resembles a narrow piece of cellophane tape, and can be found behind and above the silver bar on which the printhead rides. Easily broken ... use caution when cleaning with a cotton swab dampened with water or rubbing alcohol. When dirty from overspray, the strip can cause all types of problems.
In the Maintenance Mode of HP and Panasonic machines there is a wealth of information. For example, print out the function parameter list to get the lifetime TX/RX/PRINT counts (usually option 3 instead of option 6 in the following example for the HP 200).
HP 200 ram clear
Press # dial dial dial dial * 6 start
Exit the maintenance mode by pressing 9 9 9 start
[Note: to print function parameter list substitute 3 for 6 in the line above]
[Note: to execute a self-test substitute 0 for 6]
[Note: to set parameters 000-999, substitute 1 for 6]
[Note: to test modem/tones, substitute 4, 5, or 7 for 6]
[The TX/RX/COPY counter is item 061 on function parameter list]
HP 300/310 ram clear
Press function 7 dial dial dial dial * 6 start
HP 700 ram clear
Press and hold stop and menu for a few seconds
Press 7 0 0
Press up-arrow key 4 times until display reads 09 memory clear
Press start
Bad line card: replace 2 transistors, 1 diode, and 1 chip. Transistors BS170 (NTE490) @ Q1; 2N3906 @Q3. Diode 1N4148 ar CR2 (next to 2N3906). Chip 74LS14 (74HC14) at U5 (near BS170).
HP 900 ram clear (same as Panasonic UF-321/322)
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
HP 900 disassembly tips (proceed with caution and at your own risk). To remove the operation panel cover: face the rear of the unit, place your thumbs in the outside edges of the document feed path, lift up on the thin edge of the cover while pulling the cover toward you. This should release "snaps" located at the outer edges of the document feed path. Facing the front of the machine, lift the cover up and toward you, then disconnect a cable attached to a board on the rear of the operation panel. To access the document feed mechanism, remove a white plastic retainer in the upper right hand corner of the ADF cover, disconnect the ground strap on the right side of the cover, and slide the cover slightly to the right until it is unhinged. The cover housing the scanner glass can be lifted off after removing several screws, popping two "snaps" at the rear corners, and then carefully popping two more snaps at the front corners of the cover. At this point you would be able to clean one scanner mirror and the ADF sensors & rollers. If you need to remove the line card, you'll have to remove the remaining covers, one screw located at the front of the power supply, four screws that hold the printer assembly in place, one screw at the right rear corner of the scanner assembly, pop two snaps at the front corners of the scanner assembly (remove a long white plastic retainer at the left front corner of the scanner assembly). After gently lifting the scanner assembly upward, the printer assembly can be removed to reveal the line card. During reassembly, be sure to check the positioning of the print paper detect sensor (the spring comes off the sensor and you get an out-of-paper error). Another observation we've made is that on some (but not all) HP 900's, there is a metal retaining clip on the left end of the paper pickup roller's shaft. Apparently the plastic lever (retainer or lock) on the left end of the axle doesn't always hold the mechanism in place in the event of a multi-feed that jams the machine, and at some point in production of the machines a metal clip was added to hold the plastil retainer firmly in place.
HP 900 set number of rings to answer (default is 2)
Press menu 7 dial dial dial dial * 1 start
Press 4 5 start clear
Enter the number of rings desired then press start stop stop
HP Office Jet / LX
For a full ram clear, press and hold * and 1 while turning the power on.
Hold the keys down for a few seconds after the display reads self test please wait then release the keys
For a partial ram clear, press * and 4 while turning the power on.
For the Diagnostics Mode hold * and 7 while turning the power on. Afterwards, new menu items will be found on the display including diagnostics. Turn the unit off afterwards to dump the diagnostic menu selection.
The original Office Jet/LX will print a scanner calibration chart/instructions.
If the modem fails, remove it. Reinstall and test.
Clear Paper Jam: Remove RX tray, press load/eject and paper should load part way; press load/eject a second time and the page should be ejected. If the page ejects ok, then it's not necessarily a mechanical problem, in which case you should clean the encoder strip and sensor. If the page does not load properly, it is probably a mechanical failure. Laserjet paper is slick on one side and may not load properly. Recycled cartridges spray excess ink on the encoder strip
Posted on Nov 05, 2007
Teis
  • 340 Answers
SOURCE: HP officejet 4355 all in one print fax scan copier to connect wit
Hi there, and welcome to FixYa,
You will find your driver at this site: - choose your operating system, download and install, plz let me know the result.
/Teis 6ef1705.png
Posted on Dec 29, 2008
SOURCE: Savin AC205
In the print output tray there is a green lever that locks the scan bed in place. Move this lever and the problem should be resolved.
Posted on Mar 28, 2009
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
UNABLE TO CONNECT TO MY PC
I am not sure this machine has an automatic Scan to PC option. Brother seems to like to avoid this part of most machines. Depending on your Operation System you will still be able to access the scanning system. The operation system would define which method it uses. Win XP you can access the scanner through the Printers and Faxes option on the start menu. Go to printers and faxes and then from there access scanners on the sidebar. Find your machine and open the inbuilt scanner software to scan your photos and save them to your computer. Then e-mail the saved files.
Aug 13, 2014 | Brother MFC 240C All-In-One InkJet Printer
Cannot scan to computer
I've been able to go into my mac and open up my printer and go to the scanner and scan from there. Good luck..
Apr 04, 2013 | Brother MFC-J625DW Wireless All-in-One...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
I have a Savin 8045e connected with USB and can't scan
its needs to be connected via network to scan and not usb i believe
Apr 12, 2010 | Savin 8035e Copier
Have a savin 8035e need to activate fax and scanning
This is the same as the Ricoh MP3500. You can find all the manuals here..
MP3500 manuals
Sep 10, 2009 | Savin Office Equipment & Supplies
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Savin AC205
Dec 26, 2008 | Ricoh AC205 All-In-One Laser Printer
Printer installation
try visiting www.ricoh.com for the driver info
Jun 13, 2008 | Office Equipment & Supplies
399 people viewed this question
Top Savin Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
