Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool dishwasher won't start
My Whirlpool dishwasher won't start. Repairman says door switches but the cancel/drain cycle works. To me that say's the door switches are OK. Right or wrong?
  • 2 more comments
  • bissel Jan 08, 2009
    I have the same problem Nothing works no lights at all till you press the pot and pan cycle button and then the drain light comes on . I have just spent $120.00 for a new curcuit board and made no difference there is a small pot with 4 wires two on each knife I don't no if this is a potentiometer no power is going to this so I'm at wits end on this thing I guess it's time to call the repair man Should have bought a May Tag .Kenmore made by whirlpool.
  • Anonymous Apr 19, 2009
    Striker doesn't fit properly and comes out. It can be pulled out easily. Apparently misaligned and does not trip door switch.
  • Anonymous May 16, 2009
    I have the same exact problem.. I'm going to try buy a switch first to see if that fixes it... then if no i'll buy the LED controle panel for $112
  • Kelly Brown Aug 01, 2012
    I have had the same problem with my dishwasher twice in the last 2 months. I found that if you run the diagnostic test As decribed in the schematic in the kick panel, the washer will be normal at the end of the diagnostic --- but I don't know why. Does anyone know why this is?
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Posted on Aug 01, 2012
  • 117 Answers
Your dishwasher has one door switch and the dishwasher will not operate if this switch is not working. So you are right!
Posted on Feb 25, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
Whirlpool Dishwasher will not start
Contact appliance repairman,
sounds like either a control problem, or the is a problem with the solenoid that opens up to let water in the dishwasher at initial start.
Jul 09, 2013 | Dishwashers
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The Clean light is flashing and unit will not start. Manual says it is a heating circuit malfunction call a repairman. Heating element tests good, wiring appears fine. What is needed?
Hi, the reason why you are getting the flashing light is because the dishwasher failed to detect a 4 degrees rise in the water temp during the first 8 minutes of the cycle. Some reasons for this is a faulty heater, door switch,(heater runs through the nuetral side of the door switch), lack of water, d/w not filling correctly, should be just below heating element. Clear the fault by pressing following order. .
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again.
Jun 13, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
3,234 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
