Question about Protron PLTV3250 32 in. LCD Television
How do I check the fuses?
TV went dead after having it for 18 months. Felt the screen and it was very hot. I would like to get inside and check the fuses, is it an easy procedure?
  • 4,889 Answers
If the screen is getting hot it may not be the fuses that have gone bad. However if you want to have a go you should look for ceramic fuses on the PS board the problem being they come in different shapes and sizes.. They might look like this
http://images.google.co.in/images?gbv=2&hl=en&q=ceramic+fuse&btnG=Search+images
PS:If you do not have adequate knowledge in electronics I would not advise you to fix it ourself as the set can hold potentially lethal voltages upto several hours after turning off. As I always say "your life and limb is worth much more than this"
Regards,
Sai.
Posted on Jan 04, 2009
My 32 inch Audiovox flat screen will not turn on????? Was on and working fine 30 minutes prior.
hello, do you mean it's dead if so the fuse inside might have blown
regardsshaun
May 12, 2012 | Audiovox Televison & Video
I have a Vizio Model P50HDTV10a and it suddenly went dead. Their is no led nothing. Its a year and 4 months old.
Is the tv still under warranty? possibly a blown fuse if you don't get anything at all, you could inspect the power area, but be aware there are dangerous voltages inside.
Jul 22, 2008 | Televison & Video
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
Picture went black during viewing and won't return
its looks ur screen is DEATH.........as u only have the set for 18 months i assume u have no warrentie left'
may go in touch with TOSHIBA and tell them ur problem u have......
but it looks to me u need a new screen,,,,,or may a service will solve ur problem,,,,,it may cost u .......but may cheaper as a new screen
Nov 20, 2009 | Televison & Video
Samsung SCX-4521F Multifunction wont power on
Power supply on the printer is faulty. It might only be a fuse though, but you have to disasemble the printer to check the fuse.
Aug 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Thermal Fuse keep failing
Fuse and element failure is related to lack of air passing over the element. The drum and fan should run even if the heater is inoperative. Find out what is stopping them, then work on heat. If motor is running, there should be air flow--pull vent hose from wall outlet--should be brisk air flow. If not, remove the lint screen and check again. If now ok, soak the lint screen in hot water and detergent. If drum does not turn, check the drive belt and if it sits properly on motor pulley.
Aug 01, 2009 | Whirlpool LER5636P Electric Dryer
Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Feb 08, 2009 | Philips 47PFL7422D/37 Television
Television just went dead. No power at all.
Maybe you get rid of the TV so I can get the screen or I get rid of mine so you can get my power pack. Let me know what you think.
Nov 20, 2008 | Dell W3201C 32 in. LCD Television
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv went dead
Sounds like it could be H.O.T which stands for horizontal output transistor or a fuse is possible. Another possibility is the FLYBACK transformer. Is there a local repair facility you could take it too? Keep me posted. Have a good day...Jay
Feb 01, 2008 | Panasonic CT-36SL13 32" TV
Protron PLTV3250 32 in. LCD Television Logo
91 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
