Question about Fisher Audio Players & Recorders
I need a wiring diagram for a fisher st-830 3-way house speaker
We need to replace the mid-range speaker but when I connect the wires it cuts the power to the woofer
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
SOURCE: Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Posted on Mar 15, 2008
  • 1257 Answers
SOURCE: bose acoustimas double cube speaker
Try to see the 2 ends at the speaker you have open and arrange that 2 springs and 2 metal clip to that 2 ends to reconfigure it properly...
Posted on Jun 17, 2008
  • 631 Answers
SOURCE: Wiring diagram for Alpine MRP-F300
From the Crutchfield site:
Owner's manual
You'll use fig.8 for the front speakers and fig.9 for the subs.
Posted on Sep 05, 2008
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
Replace 2002 Range Rover Speakers with after market speakers
Yep thats ur best bet find what one is pos and neg and just wire in new connectors. Be sure u replace with same size speaker. Ie 6x9 4x8 etc. That way no holes need to be drilled other then the ones u might have to mount the specker. As well take a note of how good the wire is running through the door to the main body if u do all this work amd pull on the wires they may have already been broken innside where the door bend is if this is ur case u will habe to re run new wires from the speaker all the way through the door. The jam. And into the side kicker panel this way u know for sure ur wires are solid. Good luck.
Feb 21, 2018 | 2002 Land Rover Range Rover
The tweeter and upper mid-range speaker quit working in one of my JBL s412p speakers. All wires are connected. Would this be a cross-over assembly problem? If so, where can I purchase a replacement?
Remove the speaker wire from your amplifier. Using a 1.5v battery place the wire on both ends of the battery. Observe if you can hear a cracking sound on the tweeter and the mid-range. If there is no sound., your speaker is busted and needs to be rewind or replaced.
Dec 06, 2010 | JBL S412P Main / Stereo Speaker
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Speakers have no sound
Remove wiring, check with another speaker to see if you get sound. If not, check amp fuse, amp wiring. Connection to the head unit.
Mar 29, 2010 | Legacy Audio LW12590 Car Mid-Range
Need to know how to wire a dual voice coil subwoofer
All a Dual Core Speaker is, is Two speakers, sort of, in one. It has Connections for the Mid-range and Woofer, so The Inner speaker, is the Mid Range and the Outer, is the Woofer. Wire + to + (Red to Red), & - to - (Black to Black)
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
WIRING DIAGRAM
yo have wiring diagram :)
send your e-mail address to southener83@hotmail.com
Apr 24, 2008 | Altec Lansing VS2121 Computer Speakers
Wiring 2 diamond crossovers into a sony xplode amp & cd player
The crossover wires have absolutely nothing to do with your cd player, all you do is wire your crossovers into the speaker slots on the amp and then wire your mid-range speakers and tweaters into the crossovers. All a crossover does is it splits the power from the amp to your mid-range speakers and your tweaters.
Aug 13, 2007 | Sony XM-2150GSX Car Audio Amplifier
141 people viewed this question
Top Fisher Audio Players & Recorders Experts
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
