Question about Ricoh Office Equipment & Supplies
Ricoh MP C2500 Touch Screen Calibration procedure
Just need to know where to go for the calibration part
SOURCE: touch screen calibration
Touch screen not working for sony ericsson P990i Mobile phone
When I hit the center some part above gets highlighted and selected and the botton part where the taskmanager and battery icons are present does not respond to my taps ... what could be the problem,,, kindly help me solve the issue.
Praveen
Posted on Jan 23, 2008
  • 126 Answers
SOURCE: afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Posted on Mar 02, 2009
SOURCE: calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Posted on Jun 21, 2009
  • 7 Answers
SOURCE: Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Posted on Nov 19, 2009
ani24das
  • 89 Answers
SOURCE: reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Posted on Feb 08, 2010
Ricoh aficio MP c3000 touch screen: displays, printer reacts to physicly pressed keys (number of copies changes on the screen etc), prints scans but does not react to touching the screen
the touch screen might be out of order, or if just when yo press something specific , as example the tray 1, an it react as you pressed something else then the touch screen need calibration. you can enter the calibration process by pressing in this right order the next buttons. first press once the yellow key then press 1993 and then press the red stop key 5 times and the lest 5th hold it for 10 seconds, after you release it press the blue number key pad 1 and then adjust the screen as it request the machine from you one order then other till the end for more info please write more info..
Oct 02, 2016 | Ricoh Office Equipment & Supplies
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
Touch screen blocked
The touch screen could have lost its calibration, but there is a good chance that it is bad, and needs to be replaced. To calibrate it, push the yellow clear modes key, then the numbers 1, 9, 9, 3, then push the red "Clear / Stop" key 5 times, and choose number one. Follow the prompts. Use a stylus or other dull pointed item. If you don't get a response, you need a new touch screen.
May 22, 2014 | Ricoh Aficio 450 Copier
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
Touch screen calibration
Press the keys listed below, please note you need to press the Clear/Stop key 5 times. The screen will change after entering the keys and touch screen calibration will be option number 1. The calibration will consist of pressing a couple of small circles on the screen.
Clear Modes->1-9-9-3->Clear/Stop(5 times)
or
Reset->1-9-9-3->Stop(5 times)
Feb 17, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Ricoh Aficio 3025 Copier LCD Touch Screen gets hang after calibration
You need to replace the screen to fix your problem. But if this machine is the model I think it is you need a whole new machine.
Jul 23, 2017 | Ricoh Office Equipment & Supplies
I have a ricoh mp 2500 copier and it touch screen its freezing what do i do to reset.so i can change the paper size on it. thank u
Please elaborate the word freezing, ithink your tuch screen is not accepting the input signal you have to do tuch screen calibration my suggestion call the tech. person to calibret.
thankyou
Dec 15, 2010 | Ricoh Office Equipment & Supplies
I have a Ricoh MP C2500 Copier and I can not select any functions on the menu when I press it with my finger
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
May 26, 2010 | Ricoh Office Equipment & Supplies
650 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
