Question about Tefal Ultraglide 1549 Iron
Tefal Pro Express - Constant Steam
I have a Tefal Pro Express, and the steam will not switch off. Normally you have to depress the button on the grip to produce steam, but the steam is constant, running thro water quickly and steaming up the kitchen. Any ideas?
Thanks
Stve2100
  • 3 more comments
  • jacquief Feb 04, 2009
    I have the same problem, my Tefal pro express constantly gives out steam. It's as if the steam button is stuck but it isn't.
  • stve2100 Feb 08, 2009
    Thank you Jacquief..that worked..patience is needed and the solenoid will release..and though it takes some time for the vinegar smell to go...the extra work is worth it.. Many thanks
  • Cracker 2 Mar 14, 2009
    I too have constant steam from my Tefal Pro Express Turbo
    John
    14th March 2009
  • Anonymous Mar 17, 2014
    Water in iron appears to be getting too hot and boiling up producing far too much steam.
  • Anonymous Mar 22, 2014
    powercord trapped inside unit only partly retracts
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
  • jacquief Feb 08, 2009
    Pleasure! Glad to have been of help. At least it will save a few quid when times are tight! I still have the smell of vinegar though! We all smell like we live in a fish and chip shop LOL!
  • magz78 Aug 11, 2010
    I searched the internet for days looking for a solution to this problem, took a while, but it worked perfectly!!! Thanks so much, your a genius!
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 | Tefal Irons
My Tefal pro iron sometimes makes noise and dont steam any more?
get rid of the calcium,and use distilled water for steam,not tap water
Jun 20, 2015 | Tefal Pro Express GV 8120 Iron
My Tefal pro express inon does not steam the generator not making noise and red light comes on
Maybe the steam switch if broken or not fitted correctly dso you can open and inspect it
Sep 11, 2014 | Irons
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Jun 09, 2008 | Irons
Tefal Ultraglide 1549 Iron Logo
1,859 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
