Question about Garden
Powermore engine leaking oil
Powermore push lawn mower (yardworks 21 inch cut) blows oil out front of engine, the oil pools on mower deck. The engine runs fine, but blows oil. Could this be a cylinder gasket issue? Also how do I install push rods and what are the valve clearances?
cxbxr_3
  • 11 Answers
SOURCE: Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Posted on Aug 12, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Posted on Nov 08, 2009
  • 198 Answers
SOURCE: won't stay running
you may need to disassamble the carb and clean it thoroughly.
Posted on May 10, 2010
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
Cannot find any information on my mtd mower
I searched it and came up with this info, at the bottom of the of the info page was a pdf owners manual, also under specs it shows the engine as a Powermore, new one on me, Huskee 21 in 2 IN 1 140cc Push Mower CARB Compliant For Life Out Here
Mar 25, 2016 | Mtd Garden
How do I replace the starter pull cord on a Yard Machine 21 inch rear bag mower
New "powermore" engine? recoil rewind starter comes as a complete assy. If the spring is broken this is your only option
Oct 28, 2012 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How do you change the oil? WHERE IS THE PLG?
If there is no drain plug in the crankcase bottom (under deck), then look for a square-head type plug on the engine side near bottom. If none there, then the mower will have to be tipped on it's side and the oil drained out of the oil fill tube.
May 08, 2011 | Kelty Yard King 21" Push Lawn Mower w/...
Oil blows out filler, checked breather hose in air cleaner housing, ok.
If your machine is filled with more than 21 ounces of oil the oil will be forced out the crankcase vent and leak out the filter. Check your oil level, correct if needed. If the oil is good you may have a bad crankcase vent.
look for help from a local dealer like www.arcolawn.com
Joe
Feb 13, 2011 | Craftsman 675 Torque 190cc 21" RearBag...
Where do i change the oil on 5.5 hp. 21 inch cut mtd push mower
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Apr 04, 2010 | Mtd 22" Yard Machine Push Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Oil for yardman lawn mower
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Oil drain plug
may be under the blade plate under the mower, usually a plug with a quarter inch square drive, you can use a ratchet to loosen it if it is quarter drive, maybe a half inch drive
Apr 20, 2009 | Garden
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
