Question about Mtd FASTATTACH MANUAL SLEEVE HITCH
Snowblower will not throw snow
MTD model OEM-190-032 i have to replace my worm drive and i cannot find a repair manual online to show me how to take it apart
  • rev380 Jan 04, 2009
    worm drive and center bering are toast .but thanks again i did take it apart carfully i was hoping what i was doing was the right proceedure
    .new parts are ordered and i will be up and running in no time
  • 3 Answers
If you take your time and remove the worm drive, carefully, then the order of installation is reverse for getting it back together. Remember to take your time and keep your cool and put all the parts back. If you have left over parts you did something wrong.
Also your local library may have the manual for your machine. Good luck
Posted on Jan 04, 2009
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Where is neutral? wheels are locked & won't push forward
there could be a loose or stuck gear in drive system.
press the helpful button below and check out the link below
How to Repair Stuck MTD snowblower drive system
Jan 15, 2016 | Mtd Yard Machines 24" Two Stage Snow...
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
My thrower stopped throwing (and going). The manual said to adjust or replace the belts. I did. Now it throws but no drive wheel action. The manual is just about useless. Talking to Sears is like talking...
Actully yes although you seam to have a fairly good understaning of what is going on
There is a clutch when you push that drive lever down it tightens the belt.
It could be the trans but I would look at the level down the cable to the pulley that it is moveing before I pushed off the nearest cliff
Mar 13, 2015 | Craftsman 21" 179cc* Single Stage...
Mastercraft 5 hp snowblower parts list
control cable for a snow blower model #31a612e515
Jan 15, 2013 | Mtd Snowthrower Snowblower 5 24" Parts...
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
I have a mtd snower blower the engine and auger work buk the wheels stop turning
The most common cause of this is the drive belt is worn or broken. Sometimes the drive cable stretches (from the handle to the trans)
To check the belts and tension you remove the cover (usually plastic) in the middle of the snow thrower to look at the belts. Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side) The model number looks like 247.123456.
The belt closest to the engine drives the transmission. With the engine not running, have someone depress the drive lever and check the belt.
You can get parts for your Craftsman and most MTD made models through searspartsdirect.com or jackssmallengines.com.
If you are unfamiliar with repairing machines you can get your MTD snow blower repaired by taking it to your local Sears. They will have a technician troubleshoot and repair the unit.
Jan 13, 2011 | Garden
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
Mtd FASTATTACH MANUAL SLEEVE HITCH Logo
539 people viewed this question
Top Mtd Garden Experts
Dwain Pippen
Roland W VanLue
Roland W VanLue
Jim Parker
Jim Parker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
