Question about Dryers
Hotpoint tumble dryer TCYM750C-how do i remove transit bolts
How do i remove transit bolts
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
SOURCE: free manual
Hi Mark,
Try putting this into the address bar of your browser
http://laundry.manualsonline.com/manuals/mfg/hotpoint/aquarius_aquarius.html?s=fpw
Posted on Mar 22, 2009
  • 742 Answers
SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Posted on Oct 30, 2009
  • 22 Answers
SOURCE: hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Posted on Nov 19, 2009
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
TCYM750c. Why won't drum rotate?
possible broken drive belt on the drum
motor start run capacitor failed
motor burnt out
Oct 10, 2015 | Hotpoint Dryers
White knight cl372wv tumble dryer
-Are you talking about screws...? If so. Yes. It's on the back panel cover.
-Transit bolts are the bolts that hole the unit on a box crate only.
-After the unit has been set up. I think it already remove before set up.
Good luck
Mai
Dec 27, 2013 | Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
Need to take apart a hotpoint tumble dryer vtd00t
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Sep 21, 2010 | Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Fixed new belt on hotpoint v3d00 tumble dryer now bangs on motor
the rear of the drun runs on a shaft part no 1703038 anythin from £10- £15.00 on ebay just type in hotpoint shaft kit
Feb 10, 2009 | Hotpoint Dryers
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
527 people viewed this question
Top Dryers Experts
