Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door problem
My garage door will not open fully when I push the bottom on the wall. The problem started the door will only open a small amount when I push the button, but at that time I can push and hold the button to open it fully. Now even with push and hold the button it only opens about 2 feet.
Thanks
Alex
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
If you have a Chraftsman/Liftmaster:
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up and  down force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing  the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Posted on Jan 04, 2009
How do i set the travel limits on my craftsman garage door opener 139.53919
  • Open the garage dooricon1.png fully by pressing the wall control button. The bottom section of the door should be right at the header in the "full open" position. If it is too far back, the door cable can become misaligned. If it is not back far enough, you may not be able to get your vehicle in and out of the garage.
  • 2
    Position a stepladder behind the garage door openericon1.png motor. Locate the limit adjusting screws on the left side of the motor housing. Have a friend stand by the wall control button.
  • Sponsored Links
  • 3
    Insert a screwdriver into the slot for the "up limit" adjustment screw. Turn it to the right to decrease the door travelicon1.png and turn it to the left to increase it. Turn the screw in small increments.
  • 4
    Close the garage door by having your helper push the wall control button. Notice the seal between the door and the floor--there should not be any light coming through. Adjust the "down limit" screw in the same way if necessary.
  • 5
    Operate the door by the pressing the wall button and check your adjustments.
  • Read more: How to Adjust a Craftsman Garage Door Opener ' eHow.com http://www.ehow.com/how_5419011_adjust-craftsman-garage-door-opener.html#ixzz2Hm1tx0a0
    Jan 12, 2013 | Sears Craftsman LiftMaster Chamberlain...
    HOW TO RECONNECT INTELLICODE GARAGE DOOR CHAIN TO SAFETY CAM
    please read carefully your owner manual, if you do not have a recommend to download from www.fitness.manualsonline.com or
    www.manualsfactory.com
    and proceed according with common sense
    God bless you
    Sep 09, 2012 | Genie Company IntelliCode GICT390-1BL...
    I have Garage Door Opener from Sears. Wall push button & the the remote from my car open the door OK , but it does not close the door from my car (which is programmed) Wall push button close the door...
    If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
    Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Trying to clear the codes from my Garage Door opener. 41A3615, 139.53615SR, Grey Learn Button, '92 mfg date. I added a Klick universal wireless wall pad and a Klick universal remote and now my neighbor's...
    In most cases, when a garage door opens or closes by itself, or when you find your door open, upon returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
    When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes a continues signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses, and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
    If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button. It is a process of elimination.
    Mar 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Garage door wont work with remote
    If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
    Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Garage door opener remote won't work
    look for a smashed wire between the motor unit and the wall button.
    If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
    Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
    The second thing would be a bad wall button or a remote with a sticking button.
    Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
    The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
    HOPE THIS HELPS
    Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Garage door opening/closing problem
    Could be a bad wall button or a smashed wire.
    Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
    If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
    The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
    HOPE THIS HELPS
    Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Door won't close unless i push button on wall several times
    You probably have a stripped gear inside opener. Take off cover and the bottom will be filled with white flakes from stripped gear
    Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
    first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
    Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Garage door went on "vacation"
    Try to remove the power cord. Be careful if you have to climb a ladder! Reinsert.
    Here are instructions for vacation mode:
    If you have a three buttom wall panel, one of the small buttons should be the lock button, push this button and hold it for a couple of seconds until the LED on the wall panel stops blinking.
    Good Luck!
    Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
